Ls430 down on power and cel.
Old Mar 25, 2026 | 03:41 PM
tbilisi79's Avatar
tbilisi79
Default Ls430 down on power and cel.
Howdy folks.
My father’s 02 LS430 with 200k miles got a check engine light. When he had it checked it said it was the rear left oxygen sensor. But for a while, the car felt down on power. I changed the MAF sensor and it helped a nit hut still it feels like the car is choking out past 3500 rpm or so.
Im wondering if the cats are clogged and that ruined the oxygen sensor.
Can i have the cats checked with a Temp reader? Whats cats doyou recommend. Most go fro 350 on rock auto. .
Thank you in advance.
Old Mar 26, 2026 | 02:34 AM
BigBoomer's Avatar
BigBoomer
Most likely the Y-pipe is cracked. If the CATs are clogged then you have a serious problem somewhere in the engine.
Do you have a specific code number?
Why would you change the MAF sensor when the error code pointed to the downstream O2 sensor?
Old Mar 26, 2026 | 07:04 AM
tbilisi79's Avatar
tbilisi79
Thanks. Maf I changed years ago and it did help a lot in terms of power. That’s why I changed it. Still I feel the car is weak in mid range and upper rpm.
Car is very quiet . But I do hear lots of suction noise when trying to accelerate. Almost like a vacuum leak from the back of the engine. What could that be?
Old Mar 26, 2026 | 12:23 PM
BigBoomer's Avatar
BigBoomer
A cracked Y-pipe sucks air into the exhaust which adds oxygen, which the downstream O2 sensor detects and thus throws a code, P0420 or P0430.
Because it is sucking in the exhaust sounds normal.
If you have a cracked vacuum hose in the engine bay, that will be what you hear when accelerating.
Old Mar 27, 2026 | 02:58 AM
tbilisi79's Avatar
tbilisi79
Thank you.
code p0161 came up.
Old Mar 27, 2026 | 05:19 AM
BigBoomer's Avatar
BigBoomer
P0161 is a heater failure in the downstream O2 sensor on Bank 2 (right side).
You will need to get the sensor replaced to get rid of that one.
That will not be causing the power loss, but a vacuum leak would cause it.
Old Mar 27, 2026 | 07:44 AM
tbilisi79's Avatar
tbilisi79
Thank you. I’ll address those issues.
Fumsinderkidte
Jul 4, 2024 02:28 PM
AkoyaLS430
Feb 22, 2024 03:49 PM
Sando68
Mar 12, 2023 01:34 AM
OliverLS
Jun 3, 2021 08:29 AM
Vr2395
Oct 19, 2019 12:53 PM
