A/C issues after ML amp swap
Old Mar 23, 2026 | 10:30 AM
HadesActual's Avatar
HadesActual
4th Gear
Exclamation A/C issues after ML amp swap
2001 LS430 Sport with ML amp.
I just recently swapped out my ML amp as I was getting no sound out of my speakers. This fixed the problem! However, Since then my A/C has stopped working. No response from any buttons hot or cold. No codes present either.
Stumped on this one. I have checked all fuses which look good and back probed my connectors. The clue so far is that the yellow wire in the smallest connector does not have any voltage. I am looking into this now but would appreciate any help if someone has had this issue before.
First post on the forum! Looking forward to more!
Old Mar 24, 2026 | 06:18 AM
alextv's Avatar
alextv
Do you still have the other amp to put back in just to test if AC comes back?
Old Mar 24, 2026 | 06:29 AM
HadesActual
4th Gear
Yes, I did try that and still did not work.
Old Mar 24, 2026 | 10:32 AM
alextv's Avatar
alextv
Since it didn't happen until you unplugged the amp I would look at all the connectors and make sure all pins are positioned properly. If you did this without unplugging the battery its possible it could be a fuse but probably not. Reason I mentioned the pins is this cars wiring carries communication and intertwined everywhere. To give an example I replaced my nav with android aftermarket and wanted to just unplug the dvd player in trunk which no longer needed and none of my AC would work.
Old Mar 24, 2026 | 10:47 AM
HadesActual
4th Gear
I have checked all the fuses and they are fine.
Checked all the pins and seem ok.
The way they are all intertwined is a bit annoying when it comes to this.
Yellow wire on the small connector is not showing any power. That is my lead at the moment.
Old Mar 24, 2026 | 12:29 PM
gearhart76's Avatar
gearhart76
2nd gear
What did you use for the new amp remote wire or did you use the speaker level/high level input? Many years ago I tapped into a wire that i thought would work for adding a remote wire and it ended up being part of the a/c system and wouldn't allow the a/c to come on when the radio was on. Even putting the old ML amp back in without disconnecting the new wiring for the aftermarket amp isn't a definitive test with these new wires still connected. Did you completely disconnect the new wiring from the system? Specifically the remote wire.
Old Mar 24, 2026 | 01:24 PM
HadesActual
4th Gear
The new amp is the same as the old just a working one. Same part number ML amp
Old Mar 25, 2026 | 06:30 AM
alextv's Avatar
alextv
Have you looked at wiring diagram and see that the yellow wire is supposed to have power.
stopdrpnro
Jan 21, 2026 08:24 PM
Lex_Giorgio
RX - 3rd Gen (2010-2015)
Jul 17, 2024 02:59 PM
Mewannalex
Aug 11, 2020 02:40 AM
kristiness
Jan 30, 2019 02:51 PM
