Garage door opener buttin programming
Old Mar 12, 2026 | 06:31 PM
Klugie's Avatar
Klugie
Default Garage door opener buttin programming
I have seen lots of Youtube instruction videos. None of them work. Anybody been successful? I have a plain Jane Chamberlain garage door system.
Old Mar 12, 2026 | 10:58 PM
Quinten's Avatar
Quinten
What procedure did you follow? I was able to program a genie GDO. You have to use the GDO's handheld remote to program the in car transmitter, then program the GDO when in learn mode.
Old Mar 13, 2026 | 05:10 AM
biacs's Avatar
biacs
For our old school cars you need to grab a Liftmaster 855LM Chamberlain bridge. It plugs into a garage outlet - find a video to set up. But set your unit to that opener, then program that to your older legacy car homelink and it works fine.
I grabbed some Command velcro and stuck the bridge door opener to the box so I dont lose it :-)
Old Mar 13, 2026 | 11:28 AM
demark1's Avatar
demark1
Good advice from @biacs : garage door openers changed aroutnd 2010+ for added security. The old car-based openers (homelink?) don't work with newer receivers. I just use a 2-button opener in my LS430, as the 2 doors are matching brands, and i don't really care. But bridge is alternative.
Old Mar 14, 2026 | 06:26 AM
Klugie's Avatar
Klugie
thanks
Old Mar 15, 2026 | 07:27 AM
Klugie's Avatar
Klugie
I ordered the 855LM bridge. Thanks. Do I need 2 bridges? ... I have 2 garage doors to control.
Old Mar 15, 2026 | 10:39 AM
Quinten's Avatar
Quinten
According to google AI one bridge should work.
855LM bridge for two openers?
Old Mar 16, 2026 | 09:30 AM
biacs's Avatar
biacs
I had to order 2 -its a 1:1 function per door opener.
Old Mar 16, 2026 | 10:48 AM
Klugie's Avatar
Klugie
ok thanks
Old Mar 22, 2026 | 05:50 PM
Klugie's Avatar
Klugie
Best Reply! Thanks sir. Works perfectly!
Old Mar 22, 2026 | 05:51 PM
Klugie's Avatar
Klugie
Not correct. The bridge will control multiple door openers. I just installed mine today.
Shawn516
Mar 19, 2025 03:36 PM
ownerrx350
RX - 3rd Gen (2010-2015)
28
Dec 21, 2014 05:29 PM
COOLIS
Dec 14, 2010 04:35 PM
Peteyoung
GX - 1st Gen (2003-2009)
Sep 26, 2007 11:29 AM
