I saw these for a good deal on marketplace in a 20x10 and 20x8.5. They said they came off of a 370z which is our 5x114.3 bolt pattern. Any chance they will fit my 01 LS430? No idea on backspacing or anything else.
I have seen Nissan rims (300Z) fit before but don't know if they used spacers. They are manufactured someone said to clear the calipers but I don't know if the 370 is the same. Center bore is 66 on Nissan and ours is 60.1.
thank you for the response. With the center cap having the Lexus emblem I was assuming they were a stock Lexus wheel that someone had put onto the nissan
Whats the offset? These look like they may hit the front almost?
No idea that’s the problem. But from what I know they seem to have a Lexus hub cap and came off of someone’s 370z. Other threads have mentioned 370z wheels fitting the front so I wouldn’t know unless I drove out to them and test fitted in their driveway before purchase. The seller doesn’t have much info, which is why I was hoping someone here would recognize the wheels
I threw this into chatgpt and suggest you do it also - chatgpt is not always correct and it is bringing up the variables like asking "what 370z wheel?". Also reminding about studs and lug bolts, offset and brake clearance. If that seller is close you may want to take off a wheel on the front and put the rim on. That is probably difficult to do when you have sellers on FB Marketplace.
Here are a few 370Z wheels to illustrate what you might be working with:
