Smart key Access
Old Oct 7, 2025 | 01:16 AM
Kenn1926's Avatar
Kenn1926
Default Smart key Access
06’ LS430 82k miles. Question regarding the smart key. When exiting my car, engine off to leave, sometimes I’m able to push the exterior door button and it locks instantly, sometimes I have to wait 10-15 seconds before either the exterior door lock button or key fob will lock it. Key fob battery is new. Thanks
Old Oct 7, 2025 | 02:11 AM
LowkeyLS's Avatar
LowkeyLS
Does it beep when you push the button or is it completely unresponsive for the 10-15 seconds?
Ive had a failing door lock actuator cause mine to have those symptoms but after continued attempts it will work. Easy way to tell is when you push the lock button inside your car make sure all doors actually lock and the little red part isnt still visble on the door lock.
Old Oct 7, 2025 | 04:01 AM
Kenn1926's Avatar
Kenn1926
Thanks for the reply, I’ve checked the locks, all function quickly/perfectly. When I exit, approximately 30% the exterior button/key fob will be unresponsive for 10-15 seconds.
Old Oct 7, 2025 | 05:42 AM
LowkeyLS's Avatar
LowkeyLS
Hmm thats odd, idk what could cause a sporadic delay like that. Hopefully someone more knowledgeable can chime in with possible troubleshooting tips
Old Oct 7, 2025 | 06:02 AM
Kenn1926's Avatar
Kenn1926
Hopefully! Thanks for the help.
Old Oct 8, 2025 | 05:43 PM
LS430inDE.'s Avatar
LS430inDE.
Let me rephrase your description to make sure I understand...
Most of the time, you can lock the vehicle using the keyfob, or by pushing the black button on the door handle. Some of the time, neither the keyfob nor the button on the door handle will lock the vehicle.
If the above is accurate, you can eliminate the keyfob as being defective, and you can eliminate the button on the door handle as being defective.
The commonality would be something actually in the car, perhaps the car's battery. Believe it or not, a weaker battery will do really weird things to the vehicle. Check the battery after the car has rested overnight. If it's 12.3v or less, you should replace it.
Another common denominator with both the fob and the door handle buttons is the Smart Key ECU. The electronics and components (capacitors) are 20 years old, and are only becoming less reliable every year. That ECU is behind the glove box, silver/gray in color with several wiring harnesses connected into it. You could try reseating those connectors or spraying some electrical contact cleaner on them. Make sure you disconnect the battery first!!!!
Old Oct 11, 2025 | 01:48 PM
LS430Lexus's Avatar
LS430Lexus
I have a similar issue. Can the Smart Key ECU be "rebuilt", similar to the Transmission ECU that controls the downshifts?
Old Oct 11, 2025 | 02:25 PM
Holden53's Avatar
Holden53
After listening to a bunch of locksmiths with me trying to get a "Master" key it sounds like they have to either flash or get into the ECU ( OBDII ? )and see the keys that are there - There is a limit of the number of keys the car remembers and I think it's five. I have also heard with the correct OBDII reader you can program a key - but I don't know if that is a "Master" key or just a Valet key. I don't have the master key that came with my LS430, instead I have a Valet key that does not open the trunk. Good luck... I'm still on this journey....
Old Oct 14, 2025 | 03:22 AM
Kenn1926's Avatar
Kenn1926
Nearly dead main battery for the win! My battery was on deaths door and I hadn’t realized, wasn’t giving me issues otherwise. Replaced it with an Everlast and the problem hasn’t occurred again.
Old Oct 14, 2025 | 03:00 PM
LS430inDE.'s Avatar
LS430inDE.
Excellent work! Thanks for posting the confirmed fix!!!
Old Oct 14, 2025 | 03:05 PM
LS430inDE.'s Avatar
LS430inDE.
I have not heard of such services....but where there's a will, there's a way. This forum is the place to ask! And your question just got bumped.
Mgsteeves
Feb 1, 2025 08:09 AM
heidihidin
Jan 15, 2018 03:03 AM
FoxfireNC
Sep 22, 2013 08:13 AM
superdudu
Jun 29, 2011 09:03 PM
MPLexus301
Aug 16, 2010 05:08 AM
