throttle body plug vs hose - why different
Old Sep 2, 2025 | 11:04 AM
pur's Avatar
pur
Default throttle body plug vs hose - why different
I've seen some folks showing the left side of the TB port being open vs plugged. When I look at mine, there's a hose connected to the port instead of a plug. Any idea why there's different configuration?
Old Sep 2, 2025 | 12:20 PM
weldthedif's Avatar
weldthedif
i think that is your power steering idle-up hose, which is normally supposed to be connected at the very top of the intake manifold.
Old Sep 2, 2025 | 01:32 PM
paulo57509's Avatar
paulo57509
That's a vacuum port for the Vacuum Switching Valve (mounted to the upper intake manifold); it's part of the Evaporative Emission System. For what ever reason, mine is plugged.
Old Sep 2, 2025 | 02:33 PM
pur's Avatar
pur
I wonder why it is optional to connect vs plug. And more importantly, what are the effects especially on gas milage....
Old Sep 2, 2025 | 03:36 PM
bradland's Avatar
bradland
I'd like to think this will vary depending where you're located.
It looks like pur is in BC, and paulo is in Ca. You both may have a different setup, per emission standards, than most of us here in the states.
In the original pic, as Weld mentioned, the hose circled in red leads to the power steering ACV. The other hose (blue) is braided and leads back to the VSV.
The ACV hose on LS400s is connected to a port on the back of the upper intake. That may have carried over to the early 01 to 03 430s? If so, the port up front would be plugged...
Also, the ports are on the upper intake manifold, not the throttle body, and not necessarily related to gas mileage.
Old Sep 4, 2025 | 04:09 PM
paulo57509's Avatar
paulo57509
Thanks for the correction. I was looking at a Lexus service manual diagram. It's difficult to tell which hose nipple is referenced.
Old Sep 4, 2025 | 04:27 PM
pur's Avatar
pur
I am looking at the most left port on the top plane. A while back, I saw other FB discussion about mechanics leaving the port opens after services. Yet another internet photo shows a factory plug on the port. I immediately look at mine (one of the photos I look a while back) which is the attached photo with a hose going to the Evap side. That's what I wonder why many options. So to speak, if emission level varies by location, how the car run with or without this vacuum line routing variation I wonder? How one version carries a hose while other leave it plug yet the evap is the same. I am in BC but the car was an import from Spokane WA before I owned it. Perhaps still under WA spec..
Old Sep 4, 2025 | 04:36 PM
bradland's Avatar
bradland
If you're still referring to the port/hose circled in red in your pic they are for a power steering valve. Not emission related at all.
It may also depend on the year model of the car...
sam89
Jun 3, 2025 03:37 AM
FlexnLexus
Mar 15, 2025 09:45 PM
TTurboVoltage
Feb 9, 2024 10:50 AM
mark98ls40
Oct 14, 2010 03:33 PM
