GPS shows Washington DC
Old Nov 16, 2024 | 02:46 PM
jamsvet's Avatar
jamsvet
Default GPS shows Washington DC
I've got a 2004 LS430 and the Nav player went out. I replaced the unit with a used one, turned it on and it shows Washington DC and I live in San Diego. I went to the screen where you reset the area and pressed 2 to change it to SoCal and it shows (illuminates) that region selected. I start the car and I'm back to Washington DC. HELP.
Old Nov 16, 2024 | 06:33 PM
paulo57509's Avatar
paulo57509
The new unit probably came from the Eastern US and has the Eastern US CD-R in it. Your old unit has the Western US CD-R in it. Hopefully, you still have the old unit.
If you still have your old unit, you need to remove the CD-R, and swap/load it into the new unit. You going to have to unplug the new unit, re-install the old unit to get the old CD-R out of it.
Attached are are the instructions that came with an original updated map data CD-R I purchased from an ebay seller. Just follow Section II. You can skip step 5.
TBH, the last update for the CD-R based navigation system was Version 13.1; this was around 2015. Even with the latest data CD-R, the maps are woefully obsolete.
File Type: pdf
Old Nov 17, 2024 | 07:02 AM
alextv's Avatar
alextv
Are you using your original dvd disc and does it display properly until you turn off and back on?
Bocatrip
Sep 22, 2022 01:54 PM
singernak
Oct 2, 2021 02:29 PM
bjc99
Oct 18, 2020 05:51 PM
Nacha
Dec 12, 2019 04:56 PM
chris07is
CL of Southern California
Apr 17, 2014 09:24 PM
