Does a new LEXUS water pump include the water pump seal
Old Apr 13, 2024 | 05:25 PM
FloridaML's Avatar
FloridaML
Default Does a new LEXUS water pump include the water pump seal
I am getting my water pump replaced as part of my timing belt job.
Part # 16100-59275-83 (priced at $96.04 from https://www.oemgenuineparts.com)
Can anyone tell me if the gasket comes with, or is suppose to come with the water pump?
Old Apr 13, 2024 | 05:30 PM
Why not buy the entire Aisin kit?
https://www.rockauto.com/en/moreinfo...t=5759&jsn=407
I don't know the answer on this specific water pump what it comes with.
Old Apr 13, 2024 | 05:43 PM
FloridaML's Avatar
FloridaML
I thought about it, but for not much more money I can get lexus branded stuff.
I wish it came in a 'kit' like is offered as Aisin branded.
Here is my parts list so far:
Part Description Part Number Source Price Engine Timing Belt 13568-09070 https://www.oemgenuineparts.com 55.4
Water Pump Related
Water Pump 16100-59275-83 https://www.oemgenuineparts.com 96.04 Water Pump Gasket 16271-0F010 https://www.oemgenuineparts.com 8 Coolant Pipe O-Ring 96761-35035 https://www.oemgenuineparts.com 3.99
Water Pump Related
Camshaft Seal 90311-71002 https://www.oemgenuineparts.com 37.65
Crankshaft Seal 90311-A0001 https://www.oemgenuineparts.com 12.31
Timing Belt Tensioner Pulley 13505-0F010 https://www.oemgenuineparts.com 112.34
Timing Belt Tensioner 13540-50030 https://www.oemgenuineparts.com 65.46
Serpentine Belt 90916-02586 https://www.oemgenuineparts.com 47.65
Oil Filter Adapter Seal 15692-50020 https://www.oemgenuineparts.com 1.37
Valve Cover Gasket (right) 11213-50031 https://www.oemgenuineparts.com 18.38
Valve Cover Gasket (left) 11214-50011 https://www.oemgenuineparts.com 18.38
Total 476.97
Old Apr 13, 2024 | 05:45 PM
Aisin kit is OEM except timing belt is different. Not better or worse just different. You can buy OEM if you want but you're paying more for no benefit.
Cam/crank seals and drive belts I always buy from the dealer.
Old Apr 13, 2024 | 09:00 PM
LS430Lexus's Avatar
LS430Lexus
If you want OEM, call Belle Lexus Online Parts in Scottsdale. They are having a 15% off, free shipping sale. The parts guys will give you the part numbers for what you need, then they direct you to online portal and you order. They will tell you what you need. Also, if you can't find an independent try a Toyota dealer. I bring the parts and they do the labor. The same engine is used in Toyota trucks so the mechanics are very familiar with the job. Price comes out midway between the Lexus dealer and an independent. Good luck.
Old Apr 13, 2024 | 09:44 PM
AmdEmAll's Avatar
AmdEmAll
Just buy parts from https://parts.belllexusnorthscottsdale.com/
And yes the OEM water pump comes with the gaskets and new bolts.
Old Apr 15, 2024 | 08:43 AM
LatinLS430's Avatar
LatinLS430
Bell Lexus has the kit on ebay with part numbers
https://www.ebay.com/itm/23486507072...YAAOSwd4tT95hO
You can probably get a better deal with their sales they are having.
atikovi
Jul 30, 2021 10:09 PM
Yarners
Nov 22, 2020 01:29 PM
Lexi66
May 18, 2016 07:28 PM
soaringsc3
Mar 1, 2009 01:41 PM
