PFL '03 Headlight adjustment?
Old Jan 3, 2024 | 02:58 PM
tealchief's Avatar
tealchief
Default PFL '03 Headlight adjustment?
Hey guys, is there any adjustment to the PFL 2003 HID headlights IE: 'up/down'?
I find that mine are sufficiently bright but seem to point too far down.
Thx in advance..
Old Feb 8, 2024 | 12:08 PM
StanVanDam's Avatar
StanVanDam
Not sure what PFL means (pre-facelift? Specifying exact year or even 2001-2003 would suffice..). Look at the headlight, see sticker saying something about vertical adjustment nearby, stick 10mm deep socket into that hole, rotate. This adjusts both low and high beam simultaneously via a metal connecting rod. If your high beam is good, remove the plastic cover, take the connecting rod out, then adjust the low beam. Reinstall connecting rod after if you want your high beam keep their auto-leveling function (tied to low beam auto-level).
Old Feb 8, 2024 | 01:27 PM
tealchief's Avatar
tealchief
Thanks man, appreciate it
THE350
GX - 2nd Gen (2010-2023)
56
Feb 9, 2021 06:07 PM
shawnharpe
Jan 2, 2013 08:30 PM
scottys209
Apr 11, 2011 10:13 PM
Slvr surfr
Sep 14, 2010 11:41 PM
