Checking Trans Fluid Level
Old Mar 18, 2023 | 01:18 PM
lorenr's Avatar
lorenr
Question Checking Trans Fluid Level
Cars such as 2001 to 2003 LS 430's require Toyota Type IV automatic fluid.
Do you check it cold, hot, running or engine off?
Checked mine off and cold. It was full. However, I needed to add another quart to keep it from slipping as I backed out of my garage and slightly up hill.
What is correct?
Old Mar 18, 2023 | 02:04 PM
alextv's Avatar
alextv
Looked in my manual for 2001 LS430 and does not tell you how to check it but I have always done hot running. I think it tells you on the dipstick when you pull it out but not sure without looking.
Old Mar 22, 2023 | 10:06 AM
RipCityLS's Avatar
RipCityLS
Always check when hot, running in P. If you added a quart when it showed full while cold, you are overfilled.
Old Mar 22, 2023 | 04:17 PM
Bocatrip's Avatar
Bocatrip
What is correct?
If I remember correctly, when I had my radiator replaced years ago at Lexus, I was told to check it after driving to operating temperature, shut the car off for 30 minutes, and then check again while idling. Owning a 2001, I'm aware how blessed I am to have an actual dipstick. It's a royal pain checking 04-06s.
stanleybg
Mar 22, 2019 12:08 AM
DiabloX22
GX - 1st Gen (2003-2009)
Mar 26, 2017 07:38 AM
portion
Dec 6, 2008 03:22 PM
94GS3
Apr 26, 2001 11:34 AM
