" Help Needed 95' LS400 code p1300 rough idle no acceleration"
Old Aug 22, 2022 | 05:22 AM
Wesley39's Avatar
Wesley39
Default " Help Needed 95' LS400 code p1300 rough idle no acceleration"
Long start, & I have to hold the accelerator to the floor in order for it to pick up speed. Rides normal after awhile
Old Aug 22, 2022 | 07:07 PM
Yamae's Avatar
Yamae
The code P1300 simply means that there is no feedback signal from the ignition coil. You need to narrow down what is causing it. The highest possibility is the failing ignition coil in my past experience. Sometimes, other related parts are causing it. I'd analyze the ignition system using an oscilloscope with a high voltage prove and a current sensing adapter.
Old Aug 26, 2022 | 10:11 AM
Wesley39's Avatar
Wesley39
Thanks yamae
wileyam
May 23, 2021 03:22 PM
esdad71
13
Sep 10, 2016 08:04 PM
renato902
14
Jun 13, 2010 06:20 PM
500amg
Jul 23, 2003 09:56 AM
