Exhuast help needed
Old Jul 30, 2022 | 07:38 PM
WheresLiam's Avatar
WheresLiam
5th Gear
Default Exhuast help needed
So in the recent two years of me owning my LS400 I have chopped off the mufflers and resonators for a full straight pipe from the end of the y pipe from the cats and I have gotten God speed Coilovers. I dropped the front end about a inch and a half and the rear end 2-3 inches. With that my exhaust hanger at the end broke and has been weighing down my exhaust causing it to scrap on anything and/or everything. Since Dropping the front end to a Inch and half my exhaust has been scrapping more aggressively. I went to figure out what part of my exhaust is scrapping and it comes to my conclusion that it may be the 45 degree angle of the exhaust just after the cats. I am here to get some help on what I should do for the exhaust so that I can keep it at the height it is now and not scrap so aggressively on speed bumps at really slow speeds. Thank you for reading please all help is appreciated.
Old Aug 1, 2022 | 09:45 AM
timmy0tool's Avatar
timmy0tool
you will need to get the 'downpipe' exhaust tucked up even further, and unless you're good with a welder you will need to take it to an exhaust shop to have it done.
more:
https://www.clublexus.com/forums/ls-...k-exhaust.html
Originally Posted by Schnitz
OK. Just got back from a local exhaust shop. This is what they suggested to do.
Cut the flange off the bottom of the cat and weld a new piece of mandrel bent pipe to it and add a new oxygen sensor bung. Like this:
This would join the centre pipe to the cat for good but I don't see a downside to that.
They said they've never been able to figure out the purpose of the circled piece. The weld is also letting loose at the arrow which will cause an exhaust leak. They don't think its a necessary piece and have suggested to not replace it.
Any thoughts?
superpower
Apr 17, 2012 11:09 PM
PES300
Sep 18, 2005 08:54 AM
Lex2Go
Performance
13
Mar 16, 2005 11:53 PM
RobSoVIP
Oct 6, 2003 02:03 AM
