Leaking power steering pump fix
Old Jun 19, 2022 | 04:48 AM
LSnewb's Avatar
LSnewb
Default Leaking power steering pump fix
Took my 97 LS400 to pepboys due to a PS pump leak and they ran a dye test and told me its likely coming from one of the O-Rings. Im on a low budget so id prefer to buy just the pump without the reservoir if possible but if it happens to be the O-ring in between the pump and reservoir thats leaking would just replacing the pump cut it or would I need both?
Old Jun 19, 2022 | 07:15 PM
paulo57509's Avatar
paulo57509
You can just have the pump replaced. The reservoir from the old pump will be swapped over to the new pump. Provided they change the reservoir-to-pump seal, you should be fine.
Old Jun 20, 2022 | 01:00 AM
LSnewb's Avatar
LSnewb
Ok ill make sure to ask for that thank you!
Old Jun 20, 2022 | 10:01 AM
bradland's Avatar
bradland
If you're on a low budget do your due diligence here first without spending a dime. This is not a simple problem that's easily fixed.
If PB did a dye test ask to see where the leak is evident and take several pics. Post the pics here and let the forum guide you 👍
I cannot stress this enough, this is not a problem that's easily fixed with aftermarket parts.
First Gen Power Steering Bible
How to fix powersteering leak on 98-2000 LS400's
All in One - Power steering fix(s). Solenoid/ACV plug/Drain-Flush/Bleed system. -DIY
Old Jun 21, 2022 | 09:55 AM
timmy0tool's Avatar
timmy0tool
this seal is a ~$2 o-ring that you can replace yourself if you have basic hand tools. there are other o-rings but this is the main culprit for leaking PS fluid on the LS!
Old Jun 23, 2022 | 02:19 PM
CLLEXUSS's Avatar
CLLEXUSS
If they want to replace the entire assembly, that's what a lot of shops do now a days. It's easier for them and decreases the odds of you coming back with more power steering problems related to your power steering. So they'd rather replace everything. Right or wrong just seems how it is.
overclock
Nov 12, 2020 12:33 PM
Eds98LS
17
Dec 12, 2012 03:30 PM
cesna12
Dec 19, 2010 09:23 AM
Tymboo
Nov 13, 2006 08:44 PM
ozzie
GS - 1st Gen (1993-1997)
Apr 29, 2006 09:41 PM
