Check Engine Light Bulb
Old Mar 19, 2022 | 02:29 PM
fredbobo's Avatar
fredbobo
Default Check Engine Light Bulb
I have a 93 LS400 and the check engine light bulb is out. I searched and thought I had the right part number but it doesn't fit.
Anyone know what type of bulb this is? Would like to get an LED replacement if possible. Thanks.
Old Mar 20, 2022 | 04:03 PM
fredbobo's Avatar
fredbobo
I think it might be part # 84999-10320. Would be great to find an LED replacement. And one that's not $10 per bulb since there are a bunch in the cluster.
Old Mar 20, 2022 | 04:25 PM
paulo57509's Avatar
paulo57509
That bulb is called a neo-wedge bulb.
Old Mar 20, 2022 | 04:33 PM
Should be able to figure out by counting the number of like bulbs
https://www.japan-parts.eu/lexus/us/...cal/8301_meter
Don't use an LED here they are not 100% reliable, the factory bulb lasted 30 years.
Old Mar 20, 2022 | 09:46 PM
Yamae's Avatar
Yamae
It's a 83101-20080. In case when it's not available locally, you can buy it from the parts seller Amayama below. Problem is that the shipping cost is often more than the part cost.
https://www.amayama.com/en/part/toyota/8310120080
There is a way to use an LED but additional resistors are usually needed as is explained here. In order to match the brightness, a current limiting and a current bypassing resisters should be implemented as well as to match the polarity. Without the bypass resistor, the LED would emit the light even when the circuit is not driven since an LED works even the current is extremely small. I only recommend this method for people who are skilled doing these type of affairs.
Old Mar 21, 2022 | 04:58 PM
timmy0tool's Avatar
timmy0tool
yes correct. there are different types depending on size.
once you know the size, just find the LED equivalent and color you want:
gookies
RX - 1st Gen (1999-2003)
Nov 5, 2018 04:44 AM
bluemist
Apr 30, 2017 01:44 AM
levinsoy
GX - 1st Gen (2003-2009)
Jan 5, 2017 02:34 PM
RookieLEX
Sep 6, 2016 02:05 PM
seanyoon
Nov 18, 2011 04:26 PM
