Speedometer incorrect
Old Apr 21, 2021 | 02:18 PM
dawson128's Avatar
dawson128
Default Speedometer incorrect
Hello everyone,
Would anyone know what drives/outputs signal for the speedometer? I have a 2000 LS400 and it is reading very low. The needle comes up from 0 once I get to about 40mph and from there, continues to read about 40mph low.
I'm assuming the ECU is getting a correct signal, I can reset my average speed while driving and the first value is my true speed. I would say the cluster is just dying but the needle still moves, just 40mph too late.
Any ideas?
Thanks,
-Dawson
Old Apr 21, 2021 | 02:22 PM
dawson128's Avatar
dawson128
Another bit of info to add. I have put maybe 15 miles on the car since this started, no cel yet. Car drives fine, shifts fine, cruise control works. One thing however is that the car did stall at the light the other day which it has never done. I may start checking grounds.
Please let me know if anyone has any ideas or could tell me how the speedo works on a '00.
Thanks
Old Apr 21, 2021 | 04:09 PM
CELSI0R's Avatar
CELSI0R
There are a lot of threads about the lubricant for the needles causing them to be sticky on 1998-2000. I can't find the one I remember reading, but here is one I found after a quick Google search:
https://us.lexusownersclub.com/forum...nd-tachometer/
I don't have any personal experience with the UCF2x models, but I believe this could be related to the issue you're seeing.
There's a few threads here somewhere, and at least one for the lubricant, which may have been called "fluid." Some digging around should find them
Old Apr 21, 2021 | 05:23 PM
dawson128's Avatar
dawson128
I've seen the sticky gauge problem, it has happened on my car before and is always resolved with smacking the dashboard. I believe this is something different though, either a sensor issue or an issue with the circuitry in the dash or the ecu controlling it even
Old Apr 21, 2021 | 11:56 PM
Yamae's Avatar
Yamae
Does the odometer work fine?
If so, sensors and the ABS/TRC/VSC computer are OK but the cluster meter alone is not OK.
https://www.clublexus.com/forums/ls-...l#post10280416
Kip
Oct 14, 2020 11:10 AM
ml30306
Jul 21, 2011 07:38 PM
VIPNiSS
Mar 4, 2009 03:34 PM
jenya
May 1, 2007 11:02 PM
LamSV
Oct 27, 2003 03:30 PM
