O2 Sensor readings - Are these in spec?
Old Feb 8, 2021 | 05:41 PM
e30antonio's Avatar
e30antonio
The thermostat was swapped and it appears to be working as it should now. Time till operating temp is now about 5 mins instead of 7. The old thermostat looked to be stuck open/ stuck in its extended position.
I have both oem coolant temp sensors (top of thermostat housing and bottom corner of radiator) coming in and will see if that addresses the catalyst issue.
Old Feb 22, 2021 | 05:24 PM
e30antonio's Avatar
e30antonio
I'm looking into exhaust leak(s) now. Does anyone know if the 1UZs use exhaust gaskets? Specifically for the input/output of the catalytic converters? Because I'm just seeing them as metal-to-metal.
My Miata has gaskets on both flanges of the converter...different car / different needs though.
Old Feb 22, 2021 | 05:46 PM
Yamae's Avatar
Yamae
See the drawing. 17410B and 17451 are gaskets for catalytic converters.
Old May 24, 2021 | 05:05 PM
e30antonio's Avatar
e30antonio
Conclusion: The original p0430 code went off by itself and stayed off for about 1,500 miles. The catalyst system FINALLY showed as "complete" and I was able to get it smogged, and it passed.
So I guess changing the post-cat (downstream) O2 sensors with different ones and/ or fixing a vacuum leak on the PCV nipple (the thing sticking out of the valve cover) cleared the issue.
Hopefully this helps someone in the future.
Old Sep 22, 2025 | 11:01 AM
Joey779's Avatar
Joey779
1st Gear
Hi, I have the same problem recently. Got exactly the same downstream o2 readings as yours. Did the readings changed back to normal when you replaced the downstream o2 sensors?
Acrad
GX - 2nd Gen (2010-2023)
37
Nov 22, 2020 10:43 AM
andykao
IS - 1st Gen (2001-2005)
Nov 5, 2019 06:57 PM
poloking24
Nov 3, 2014 01:46 PM
brad11140
Apr 24, 2014 09:19 AM
