Leak Above diff?
Old Dec 13, 2020 | 07:17 AM
Thessejway's Avatar
Thessejway
Default Leak Above diff?
1995 LS400
​​​​​​Does anybody recognize what this oil leak is?
It feels very greasy, so my guess is a bad CV Boot maybe?
Old Dec 13, 2020 | 08:26 AM
fondu's Avatar
fondu
My guess would be the same as yours but i am not 100% convinced... if so then it looks like pretty much all the grease came out of the boot
What does the boot look like underneath the mess...?
Old Dec 13, 2020 | 08:59 AM
WhiteUCF's Avatar
WhiteUCF
That looks too thin to be cv grease. Cv grease is like suspension/bearing grease, thick and gooey. You didn't have a container of oil/trans fluid in the trunk and it leak through the trunk grommets? Is there any fluid where the axles and/or drive shaft meet up to the differential? Could be the shaft seals.
Old Dec 13, 2020 | 09:35 AM
fondu's Avatar
fondu
I will have to second that. One boot on my '94 had teared on the diff side but the far side away from the cv joint. The grease made a very distinct straight line and was raised like little hills and only in a half inch wide line. Not a huge greasy mess all over the place including the rear of the subframe like yours. I understand after 25 years grease can break down and liquify but not to the point of what we see in the picture.
Hopefully it is not gear oil coming from the diff...
Old Dec 13, 2020 | 07:22 PM
YODAONE's Avatar
YODAONE
Originally Posted by Thessejway
1995 LS400
Have you checked differential fluid level?
The first image of your rear differential bushings suggests they are cracked.
If extracting differential to replace seals, consider replacing differential bushings.
Old Dec 13, 2020 | 07:25 PM
YODAONE's Avatar
YODAONE
1995 LS400
Has anyone checked differential fluid level?
Also, it appears from first image that your rear differential bushings are cracked/separating..
Wlpls430
Build Threads
48
Jan 1, 2022 09:48 AM
gr8bryt
Dec 14, 2020 09:15 AM
Amirjon
RX - 3rd Gen (2010-2015)
Apr 22, 2020 03:02 PM
