UR Engine
Old Dec 11, 2020 | 09:06 AM
gr8bryt's Avatar
gr8bryt
Default UR Engine
Hey CL folks! I've been doing some research, but have not been able to come up with any answers relating to the actual dimensions of the various UR engines. I'm guessing that that the 2UR is a 1UR with a larger bore/stroke for the increase in displacement. My main question is how does the 3UR compare to the 2UR in physical size and dimensions? I'm not sure if which forum this question belongs, so I just put it here with hopes of getting some input. Thanks in advance for your help!
Old Dec 11, 2020 | 04:12 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
the 1UR I believe is the 4.6L V8 from the GS/LS line from 2007-2017. The 2UR is a 5.0L from the LS600hL. other than internal displacement, they are nearly identical. I would venture to say the exterior dimensions are the same.
Old Dec 11, 2020 | 04:45 PM
Sargon's Avatar
Sargon
Longer stroke: taller deck, wider intake manifold, greater width across the exhaust manifolds, less hood clearance than shorter engines.
Old Dec 12, 2020 | 06:49 AM
gr8bryt's Avatar
gr8bryt
I had a feeling that the 1UR and 2UR were the same externally. My biggest curiosity is just how much bigger/wider is the 3UR to the 1UR? The RC fits the 2UR, how much modification would it need to accommodate the 3UR? I'm guessing custom exhaust manifolds at a minimum, but would the 3UR fit otherwise?
Old Dec 12, 2020 | 06:58 AM
gr8bryt's Avatar
gr8bryt
Here's a picture that I found of the Red Bull RCF w/ 3UR. I realize that the front end was cut up to accommodate the extreme steering angle, but it seems the engine "fits"
Old Dec 12, 2020 | 11:42 AM
Sargon's Avatar
Sargon
Everything clears the hood nicely.
Oh wait...
Old Dec 14, 2020 | 09:15 AM
gr8bryt's Avatar
gr8bryt
The hood did require some modifications to accommodate the S/C, but otherwise it looks like it fits fine.
2013FSport
Dec 16, 2020 11:22 AM
tich
CT 200h Model (2011-2017)
Mar 14, 2020 03:55 PM
4NMOPAR
Oct 25, 2005 02:09 PM
lexboy
Aug 1, 2003 03:01 PM
