Help fixing my vacuum leaks
Old Nov 25, 2020 | 06:26 AM
YODAONE's Avatar
YODAONE
Default Smoke Machine
Originally Posted by pgmedia
I've found the leaking lines i just need to go to a toyota dealership and see what they charge for the lines or of they could cross match them. Or if anyone knows the size of the hoses i could order them online
These gentlemen perfected the do it yourself smoke machine:
Old Nov 25, 2020 | 10:40 AM
pgmedia's Avatar
pgmedia
Originally Posted by gemcitylex
How did you clean the MAF sensor? I have heard claims that it is very sensitive and breaks with little provocation. Thanks
From my understanding there are two small wires in the MAF that are about the same thickness of a piece of hair and very delicate. So I used some CRC mass airflow sensor cleaner and sprayed the MAF from a little bit of a distance. not sure if it did anything or not because my engine is still running lean from my vacuum leaks
Old Nov 25, 2020 | 10:49 AM
pgmedia's Avatar
pgmedia
they did more than perfect it lol
Old Dec 1, 2020 | 12:42 PM
Phantom410's Avatar
Phantom410
I would look into what hoses can be deleted safely, then use a smoker to sniff out any other leaks. Should save you alot of time and hassle.
ChaseMcCla
Nov 17, 2020 10:34 PM
cd051925
Oct 10, 2017 09:22 AM
hfsdude007
Feb 7, 2013 06:12 AM
hfsdude007
Feb 5, 2013 09:50 AM
1of120
Jan 10, 2010 03:30 PM
