97 LS400 wheel locked up
Old Sep 21, 2020 | 03:27 PM
Raraujo619's Avatar
Raraujo619
Default 97 LS400 wheel locked up
I was driving on the freeway and something felt weird as I exited. I came to a stop then my front right tire makes a grinding sound then I pull to the side and the right wheel locks up. I can reverse the car and drive forward a few feet until it won’t move, what could have happened?
also if I don’t turn the engine on, it’s able to coast freely in neutral
Old Sep 21, 2020 | 06:18 PM
timmy0tool's Avatar
timmy0tool
any check engine lights? i assume it's the rear right wheel?
my first instinct is that the brake calipers are locking up or there is a problem in the diff.
what's your mileage?
Old Sep 21, 2020 | 07:41 PM
Raraujo619's Avatar
Raraujo619
no lights, I’m at 226,000 miles. It’s the passenger side front wheel, maybe the caliper. Before that I noticed the brakes squealing in the morning and then occasionally when I brake I heard a clicking sound from up front
Old Sep 21, 2020 | 07:43 PM
datstockls's Avatar
datstockls
When's the last time you had a brake job?
Old Sep 21, 2020 | 08:48 PM
sdls's Avatar
sdls
How about you take off that wheel and start poking around?
Old Sep 21, 2020 | 10:51 PM
Raraujo619's Avatar
Raraujo619
I bought the car 2 months ago and was told the front brakes were changed and only the rears needed attention, should’ve checked the fronts too
Old Sep 22, 2020 | 06:45 AM
sdls's Avatar
sdls
If one of the caliper bolts fell out from insufficient torque when the brake service was done then the caliper can swing out of place and land on the wheel. That’s one possibility of many
Old Sep 22, 2020 | 07:27 PM
sha4000's Avatar
sha4000
Take the wheel off the problem should be obvious when you look in there.
Old Sep 23, 2020 | 01:42 PM
timmy0tool's Avatar
timmy0tool
squeaking sounds are normal when cold or the ambient temps are right. my 97 always had a squeak upon first application then went away as it heated up in the winter - but it should never actually lock up!
Old Sep 23, 2020 | 01:44 PM
timmy0tool's Avatar
timmy0tool
but that wouldn't explain why the car would roll fine when the engine is off unless the caliper unlocked by coincidence - good thought!
it's a head scratcher until the OP removes the wheel and inspects.
Old Sep 24, 2020 | 09:44 AM
wolfy53's Avatar
wolfy53
Yeah i agree folks. he needs to just pull the wheel and inspect. Likely some frozen pistons. Not a lot that can go wrong. However with the lack of understanding on the orginial question, it may make sense to have him take it to a shop, if he/she doesn't know what they are doing. Stopping is typically not optional! Not worth a risk of their lives or others.
hillsnow
16
May 13, 2020 04:42 PM
dieselpb
Dec 16, 2016 07:58 PM
vredniykot
Jun 21, 2007 06:44 PM
