Pulling a 1UZFE-VVTi help?
Old Aug 6, 2020 | 05:46 PM
e30antonio's Avatar
e30antonio
Default Pulling a 1UZFE-VVTi help?
(my previous episode: [url]https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/946665-jdm-1uzfe-vvti-swap-into-a-usa-ls400.html)
I'm trying to remove the engine from my 2000 LS400 but I'm stumped on one thing. How do I go about removing the harness connections? I understand it's best to unplug the main connectors from the chassis and not all the individual plugs from the engine. So just unhook the connectors from the fuse/relay box? How about the large accordion tube that goes into the passenger side firewall? A checklist would really help! Thanks!
I've already removed:
radiator
battery
fan
ac compressor - the refrigerant hoses are still attached
exhaust flange nuts
oil
ps fluid and tranny fluid
Next I'll be removing the trans mount and driveline.
Old Aug 6, 2020 | 05:56 PM
YODAONE's Avatar
YODAONE
[QUOTE=e30antonio;10864225][my previous episode: [url]https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/946665-jdm-1uzfe-vvti-swap-into-a-usa-ls400.html ]
radiator
battery
fan
exhaust flange nuts
oil
Are you extracting the transmission along with the engine?
Old Aug 6, 2020 | 06:09 PM
e30antonio's Avatar
e30antonio
[QUOTE=YODAONE;10864228][QUOTE=Are you extracting the transmission along with the engine?[/QUOTE]
Yes, that's my plan. I'm doing this on flat ground so I'm guessing it'd be easier to pull them together.
Old Aug 6, 2020 | 06:32 PM
Unplug the engine harness from the ECU and pull through the firewall. Pull the engine with harness intact. At the factory the engine is installed with the harness complete and attached to the engine.
Old Aug 14, 2020 | 08:56 PM
e30antonio's Avatar
e30antonio
If anybody has a checklist of what to unhook from the chassis it would help!!
ummkay3
Jan 21, 2011 09:50 AM
newgsman
Performance
Jul 30, 2009 11:34 PM
madmax98
Nov 18, 2007 01:19 PM
Colby
May 22, 2004 01:20 PM
additude
Maintenance
Sep 11, 2003 06:53 AM
