Steering Rack replacement help
Old May 17, 2020 | 12:07 AM
Ahillsls's Avatar
Ahillsls
Default Steering Rack replacement help
Hello,
My rack is leaking fluid so replace won’t rebuilt. Any tips on reaching the line bolts? Also, I read a step by step how to and it said one bolt is 22 mm. Mine is a 96 and when I visually inspected they both looked smaller than 22 mm. Any tips would be appreciated, I have done brakes, rotors and inner and outer tie rods. The only thing that looks difficult are the lines.
Old May 24, 2020 | 01:16 PM
blkstealthpaid4's Avatar
blkstealthpaid4
Same here. I have to do mine on my 95.Not sure about the 22, but there is a big bolt underneath each engine mount, and that, I think holds the rack onto the lower cross member.There are two other bolts on that same cross member.It could be 22mm.There is another 17 inch bolt that I think is the high pressure hose that you need to raise the engine and get to it with a long 17 mm wrench.I was about to do mine and I realized the electrical plug was different from my original, so I gave up.
Old May 24, 2020 | 01:30 PM
Ahillsls's Avatar
Ahillsls
Did you make sure you had the proper fluid, My flushing of power steering (brown) fluid and replace with dex III has stopped my leak,
Bon
Nov 10, 2024 08:05 AM
D3AN
Jan 12, 2018 05:00 AM
Sactolex
Mar 7, 2016 03:47 AM
kyle178849
Dec 14, 2011 09:36 PM
Lexus082
Oct 2, 2008 08:59 PM
