Weird issue with my new engine , unresponsive throttling
Old Dec 13, 2019 | 06:53 AM
HarisKhan's Avatar
HarisKhan
Default Weird issue with my new engine , unresponsive throttling
Hi guys i have 1996 ls 400 recently changed its engine which is a Japanese spec 1uz engine. After 2 weeks i noticed the EGR valve was leaking so i replaced the EGR valve and after some weeks it started to misfire. When i press the gas paddle the RPM goes down and then goes up. And some times it runs great like it should but some times makes the same problem the mechanic could not track the problem and the computer showing code P0401. (Car's catalytic converters are empty) please if you have any idea whats going on then hit me up.
Old Dec 13, 2019 | 08:44 AM
HarisKhan's Avatar
HarisKhan
And now i start the car and the engine is hesitating and throwing lots of code😞😥😓
Need help 😞
Old Dec 13, 2019 | 08:45 AM
HarisKhan's Avatar
HarisKhan
Need help 😞
Old Dec 13, 2019 | 05:34 PM
Yamae's Avatar
Yamae
I judge that those multiple codes are all related to the abnormal air to fuel ratio or the off timing. I'd check the vacuum leak using a smoke machine first. It can be made easily. Actually the lady Magda is in use of a her own made smoke machine to check the leak at the link below. I worry that your EGR fixing job might cause something unwanted. Is the EGR pipe well attached to the exhaust side and the intake side? A smoke machine can tell.
https://www.clublexus.com/forums/ls-...ml#post9434048
skyshadow
NX - 1st Gen (2015-2021)
85
Jun 4, 2020 10:36 PM
classik90s
Dec 2, 2018 07:17 PM
ES3_Ray
27
Mar 22, 2009 02:29 PM
