Antenna replacement. Need tips.
Old Nov 19, 2019 | 01:52 AM
1uzfe40's Avatar
1uzfe40
5th Gear
Default Antenna replacement. Need tips.
Hello,
A while after I bought my ls, the antenna broke, the plastic cable snapped, I found a replacement one, wich was not an oem one, had my mechanic install it, only for it to break when I got home, after calling the seller and getting a new one it broke after about a month (or a bit less) of use. In every case the plastic cable snapped.
I want to get an oem one now, hopefully one that will work for longer. I know many ls users don't bother replacing them as it's a common issue, but I really like the way it looks.
https://www.ebay.com/itm/GENUINE-LEXUS-GS-SC300-LS-SC400-OEM-RADIO-ANTENNA-ROD-MAST-CABLE-86337-24181/152224472584?fits=Model%3ALS400%7CMake%3ALexus&epid=656241896&hash=item2371491e08:g:7RkAAOSwtYZcEOdS
https://www.ebay.com/itm/GENUINE-LEXUS-98-04-GS300-GS400-GS430-OEM-ANTENNA-ROD-MAST-CABLE-86337-3A100/173505278431?_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20171010182220%26meid%3Df847ff2f6f5e47e2a4f4e15fbbe23bf9%26pid%3D100891%26rk%3D1%26rkt%3D6%26mehot%3Dlo%26sd%3D152224472584%26itm%3D173505278431%26pmt%3D0%26noa%3D1%26pg%3D2332490&_trksid=p2332490.c100891.m5206
https://www.ebay.com/itm/GENUINE-OEM-LEXUS-SC300-RADIO-ANTENNA-AERIAL-MAST-ROD-W-CABLE-86337-33200/162747622053?_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20171010182220%26meid%3Df847ff2f6f5e47e2a4f4e15fbbe23bf9%26pid%3D100891%26rk%3D2%26rkt%3D6%26sd%3D152224472584%26itm%3D162747622053%26pmt%3D0%26noa%3D1%26pg%3D2332490&_trksid=p2332490.c100891.m5206
https://www.ebay.com/itm/GENUINE-LEXUS-92-95-ES300-OEM-RADIO-ANTENNA-MAST-ROD-PIPE-W-CABLE-86337-33040/163914224672?_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20171010182220%26meid%3Df847ff2f6f5e47e2a4f4e15fbbe23bf9%26pid%3D100891%26rk%3D3%26rkt%3D6%26mehot%3Dlo%26sd%3D152224472584%26itm%3D163914224672%26pmt%3D0%26noa%3D1%26pg%3D2332490&_trksid=p2332490.c100891.m5206
They all look similar, I have a 97 ls. Are these all the same?
Wich one should I get?
Thanks for help.
Old Nov 19, 2019 | 10:03 AM
RA40's Avatar
RA40
Super Moderator
The one that shows up for the US spec is 86337-50141.
https://www.mylparts.com/v-1997-lexu...enna-and-radio
May have to get into the antenna motor assembly to check-clean-lubricate it. Should not be breaking the cable if it is the correct part.
Old Nov 19, 2019 | 11:34 AM
1uzfe40's Avatar
1uzfe40
5th Gear
Forgot to mention, I have a european ls
Old Nov 19, 2019 | 09:12 PM
RA40's Avatar
RA40
Super Moderator
Yes, recognized you are in Europe. None of those listed are for your year, I'd not take the risk. The 86337-50141 is listed for 95-97 but as far as Euro or JDM spec, I don't know.
Old Nov 20, 2019 | 03:08 PM
oldskewel's Avatar
oldskewel
In case it helps, here's my experience with my '91's antenna:
The original plastic cable snapped after about 25 years, no complaints there.
I bought a replacement off eBay. Fit was OK, but it seemed to fail the same way almost immediately. After taking it apart, I saw that what happened is that the plastic cable is crimped inside a metal clamp on the antenna. The design is not great, and the cable simply pulled out of the clamp when it was first used for real. Basically, it just took a little figuring out and tuning, and I re-clamped it more carefully, and it has worked fine ever since. No chance of doing that with the original cable - in that case, the plastic is simply old, brittle, and will crack again if you tried to make it work. But when doing all that, since I had things apart and figured out how it worked, I re-used the actual original antenna, just not the plastic cable.
BTW on the fit and the different years, etc., I believe it may have to do with the length of the antenna when extended. Being in Europe, you probably work on different frequencies and the antenna may be different due to that. Most cars would not care, but these Lexi adjust the antenna length based on the FM station you're tuned to.
Jac0077
Apr 13, 2018 01:01 PM
wopdud
Nov 27, 2010 06:44 PM
keithisme
Nov 7, 2010 03:28 PM
krypto
Mar 14, 2003 02:36 PM
