P0441 p0446 are back
Old Oct 1, 2019 | 07:37 PM
Sin1UZFE's Avatar
Sin1UZFE
Default P0441 p0446 are back
So they are back. Which took longer than expected since last time battery was unplugged. I smoked the front of the car and found 2 hoses...one was leaking from the usual spot on the air intake (the nipple that breaks off) and we did the club Lexus approved fix. The other was coming off the pcv valve. Replaced the pcv valve. How would I be able to test the items in the rear namely the charcoal and vsv etc. Where do I introduce smoke back there or is there a better test? I seen some tests for same codes on camrys.
99ls
Fixd are awesome, free ones are better.
Old Oct 2, 2019 | 04:45 AM
spuds's Avatar
spuds
This gives good ideas of where to start,some generic info anyhow
I also saw this on the comments on a 1999 toyota car.....
I HAD p 0441 AND P 0446. I HAD ACCIDENTALLY PULLED OUT THE TINY HOSE WHILE REPLACING THE AIR FILTER. ALWAYS CHECK HOSES FIRST .
Old Oct 2, 2019 | 05:48 AM
spuds's Avatar
spuds
And a very helpful link right here
https://www.clublexus.com/forums/ls-...procedure.html
Old Oct 2, 2019 | 08:08 AM
Sin1UZFE's Avatar
Sin1UZFE
https://www.youtube.com/watch?v=kbgiSb-ciTk
https://www.youtube.com/watch?v=FQFULrEY3NE
Which hose?
Old Oct 10, 2019 | 04:31 PM
Sin1UZFE's Avatar
Sin1UZFE
Charcoal canister assembly is fine, but something I noticed.....I have always used 76 gas cuz its 200ft from my place, but was running low on a trip and stopped at a sinclair station. Filled up. When I got home got a CEL. with these codes....possible that fuel can do this?
Old Oct 10, 2019 | 07:58 PM
aptoslexus's Avatar
aptoslexus
Check your fuel cap.
Old Oct 10, 2019 | 08:22 PM
Sin1UZFE's Avatar
Sin1UZFE
I changed it with an oem one a year ago. Funny thing that it only happened when I used cheap gas now
Check vsc is back as well.
Raven01750
Sep 12, 2019 05:23 PM
McCloudsZJ
May 15, 2019 11:28 AM
rroy
Wheels, Tires & Brakes Forum
Aug 16, 2007 11:13 AM
Lexmex
RX - 1st Gen (1999-2003)
12
Feb 10, 2006 09:51 AM
