catastrophic engine oil leak video - LS400 '90
Old Feb 22, 2019 | 05:52 PM
kLS400's Avatar
kLS400
Default catastrophic engine oil leak video - LS400 '90
Anyone care to take a guess of the leaks cause? I'm about to find out soon, but wow this is crazy how sudden this car went from a quart every other month to a quart gone in 10 miles or less.
Old Feb 22, 2019 | 07:01 PM
oldskewel's Avatar
oldskewel
Oil filter housing?
It should be easy to find. I would just hose it clean and then see if it leaks before you even run the engine. Then run the engine just for a few seconds, stop the engine and look carefully for the source. At that leak rate it should be easy to spot.
Old Feb 22, 2019 | 07:09 PM
RA40's Avatar
RA40
Super Moderator
That's painful to watch.
Old Feb 22, 2019 | 07:13 PM
bradland's Avatar
bradland
It's coming from somewhere above the AC Compressor. You can see it run down the Compressor housing then drip straight down. The drivers side cam is directly above the AC Compressor. Cam seal or really bad valve cover leak...?
Old Feb 23, 2019 | 06:39 AM
jaaa's Avatar
jaaa
Ever heard of gravity? It's definitely above where the poster is shooting the video!
Old Feb 23, 2019 | 07:43 AM
213374U's Avatar
213374U
Left hand (driver's side) cam seal or valve cover gasket as already mentioned. They're the only 2 seals would result in drips there.
I would plan to go ahead and do timing belt and tensioner, both cam seals, crank seal, valve cover gaskets, and all 8 spark plug tube seals while you're in there. No point in doing all the work to get to one cam seal and not replace the rest given the low cost of those parts.
Old Feb 23, 2019 | 10:04 AM
oldskewel's Avatar
oldskewel
And at the very least inspect the timing belt. If it got bathed in oil, then definitely replace the belt at a minimum.
Old Feb 23, 2019 | 02:40 PM
213374U's Avatar
213374U
I would plan to go ahead and do timing belt...
Don't even bother "checking it", just swap it with everything else so you know it was all done at the same time. These parts are too cheap, and your time too valuable, not to.
kirby747
Jun 24, 2014 01:28 PM
FatBrian81
Jul 30, 2011 07:44 PM
k7q
Aug 19, 2010 11:30 PM
kmn5
Jun 25, 2002 02:00 PM
