taillamp failure
Old Feb 2, 2019 | 08:59 AM
kambam3627's Avatar
kambam3627
Default taillamp failure
i just bought this ls and i have a tallamp failure warning on dash, only when i step on breaks. im guessing its the bulbs where i circled, anyone know the bulb # or what i should try? thanks 2000 platinum
Old Feb 2, 2019 | 01:49 PM
YODAONE's Avatar
YODAONE
Check also the third brake light assembly.(Two T-5 bulbs)
Probably a good idea to replace all brake and tail lamp incandescent bulbs.
Check Country of origin (presumably manufacture) on package
Japanese bulbs are best quality.
See;
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/877094-center-stop-lamp-improvement.html
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/877653-tail-lamp-lense-upgrade.html
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/874861-side-marker-lenses-improving-color-uniformity.html
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/880190-front-and-rear-turn-signals-illumination.html
Old Feb 2, 2019 | 03:18 PM
AlaskanLS's Avatar
AlaskanLS
Before you waste money on buying new bulbs. I can clearly see the tail light you have circled is not as bright as the right one, this happens due to corroded ground wire. Check the ground wire for that tail light and make sure it's grounded properly. I went through this problem before and have wasted money on bulb but in fact it was a bad ground wire that was triggering lamp failure light.
Old Feb 2, 2019 | 06:05 PM
YODAONE's Avatar
YODAONE
Replaced my left rear tail lamp wiring harness. New OEM: $40
While everything apart replaced 20 year old bulbs.
Bulbs work or not.
Here the police look for probable cause to stop.
Burnt out or dim tail lamp bulbs are a favorite.
Lveyolfe
Mar 28, 2014 08:02 AM
jerryparks
Oct 12, 2012 12:41 PM
hfamemail
Aug 22, 2012 07:17 PM
mikeyboy
Mar 3, 2004 08:54 PM
mjr24
Jun 2, 2003 12:19 PM
