So I have one issue with my new 1999 that I have not been able to diagnose yet. Everything on the car seems mechanically sound after checking it all over. I just got new tires, so it rolls perfectly smooth.
I have a weird vibration that is coming from an unknown location. It happens when the engine revs whether it's in park or moving. It's generally pretty low in the Rev range and it is not really consistent. It's a fast pulsating feeling that seems to increase with the revs. I can best describe the feeling like "bass". You can't hear it but you feel it in the seat.
For now I've ruled out the engine mounts because under revs the engine does not move when I feel the vibration. Haven't checked the transmission mount but I feel like it wouldn't be the case if I feel it when the car is parked.
I've heard that a pulley could be out of balance. Is this a good guess?
Thanks for the help.
If you have over 100k miles, changing the transmission mount is not a bad idea, pretty simple and a cheap fix to many vibrations/ noises.
Engine mounts make a day and night difference, many owners report little vibration only to find out the mounts broken into two pieces!!! You would have to buy oem mounts specifically designed for VVTi, don’t buy cheap aftermarket ones, neither engine mounts, nor the transmission mounts.
How many miles on your LS?
Quote:
I have 114k miles. I will take a better look at the mounts soon. I need to get someone to help me rev it while I inspect the mounts. I may also get a stethoscope to better locate the issue. Originally Posted by valex
bradland
close
- Join DateDec 2005
- Location565 St Peter NOLA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:828 Times in 670 Posts
Next time you are at a stoplight put the car in neutral. If the vibration goes away it's prob the trans mount.
Pretty good chance replacing just the trans mount will fix the issue...
Like I said, the vibration happens when in park and moving. That's kinda why I don't think it would be the trans mount. Originally Posted by bradland
Next time you are at a stoplight put the car in neutral. If the vibration goes away it's prob the trans mount.Pretty good chance replacing just the trans mount will fix the issue...
bradland
close
- Join DateDec 2005
Your post is only a few hours old and the only 2 ppl who responded have suggested the same thing.
I'm not trying to be mean but, there's a tremendous wealth of knowledge on this forum, if you don't want to listen don't waste our time.
We are here to help but assuming you already know the answer doesn't do anyone any good...
RA40
Super Moderator
close
- Join DateMay 2003
- LocationCalifornia
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:490 Times in 373 Posts
Unlikely a pulley those are low mass that won't really be felt through the car. You'll hear them squealing as the races or bearings are dry worn. Top issues with vibrations are engine, tranny mounts followed by carrier bushings or the drive shaft coupling. If the vibration is present when the car is not moving, as above, tranny mount is a high possibility. Most come out in two pieces as do the engine mounts at this age. Replacing the engine mounts makes a huge difference.
https://www.clublexus.com/forums/ls-...t-coupler.html
If your car hasnt had mounts replaced, then there is a high likelihood that yours are old and worn/tearing. After I did my front mounts and the previous owner did the trans a year prior, I felt absolutely no vibration coming into the cabin whatsoever. I couldn't even feel the car start up, it was that isolated.
Plus, we're talking about 19-20 year old rubber mounts here, you may not think they're bad, but they probably are, or are very sagged by now with the weight of the engine on them for so many years.
