replacing starter on 95 LS
Old Jun 22, 2018 | 07:44 AM
Zwolle's Avatar
Zwolle
Default replacing starter on 95 LS
I need picture and info on replacing my starter on 95 LS400.
Old Jun 22, 2018 | 10:34 AM
jaaa's Avatar
jaaa
The shot above is after I had removed both intakes, taken the wiring bundle apart and had the water bridge pulled up slightly. The shot below is at the back of the engine right after I got both intakes off. I pulled them off with the fuel rails attached, although I did read some peoples accounts where they had to take the rails off. There is a wiring bundle that you will need to take apart that runs through a black plastic housing. Next you have to take off the rear coolant bridge that has the egr pipe attached to it. If you have any age on your EGR pipe, now would be the time to replace it. After you get the coolant bridge removed, you can get to the bolt on the back of the starter and remove it. All of this takes a fair amount of work and you have to take off a lot of hoses. So keep track of hose routing as you go.
Old Jun 22, 2018 | 11:23 AM
timmy0tool's Avatar
timmy0tool
my lower back hurts just by looking at these pics !
Old Jun 24, 2018 | 10:56 PM
dicer's Avatar
dicer
So did you have fun changing it?
Old Jun 25, 2018 | 01:21 PM
DVL5WRK95's Avatar
DVL5WRK95
Piece of advice: If you’re changing your starter, do your EGR flex pipe (The gold colored rib tube you see at the back of the engine behind where the starter is located) as well, since this is when it will be most accessible.
Old Jun 25, 2018 | 03:28 PM
billydpowe's Avatar
billydpowe
what are you driving now, is this a daily?
Old Jun 26, 2018 | 01:58 PM
timmy0tool's Avatar
timmy0tool
this isn't my car billy but I hope to be in an LS again, probably this time in a 99-00 model.
Zavala
16
Dec 25, 2018 12:51 AM
EPayne42
Aug 17, 2015 04:17 AM
GSbearcat
Apr 8, 2011 05:00 PM
jrowill
Jun 20, 2010 12:45 PM
Greydog
Apr 20, 2005 06:34 PM
