Driver side power window not working all the time
Hello,
So the title says it all. Sometimes my driver side windows will roll up and down without a problem and other times it won't move at all. I notice the issue mostly occurs when I roll my window up and down within a short period of time. Such as today when I rolled it up for a car wash then rolled it down. When I got home to roll it up it started to roll up then slowed down and just stopped. This has happened to me before in the past. After around 5-10 minutes of driving it will work again, however, this is very annoying. Anyone know what the issue is and how much it may cost to fix?
Thanks
Thanks
Sure you're not getting water inside the door? Only bring it up as you talked about the car wash, then later, after it had a chance to dry, worked fine. It's easy to pop off the control panel in the door and see if the switches are clean and free of debris. Going to have to figure out if you're not getting power, or the motor is getting tired and does not work all the time. Not sure you can figure this out without pulling the door panel off.
All the other windows work fine on multiple uses from the driver's door? If so, then could be something about the motor on that door only then.
Hello,
Thanks
Thanks
I have seen many aged motors for windows and door locks failed due to the shifted "Curie Point" to the lower side or the internal resistance at ambient is already increased. The quickest way to fix is to replace the motor since the PTC thermistor alone is not available easily.
FYI, I attach a photo which shows PTC thermistors in the motors although it is for a door lock. Red arrows indicate the PTC thermistors.
I've been having this problem when its really cold outside, I'm not sure if its the driver window switch and the contacts in it or what. It is very unpredictable. But whenever the temps are below 30 degrees it tends to act up more and not work.
Spray lots Silicon based WD40 in the window channels the problem will go away. I had this problem with my Toyota Land Cruiser and WD40 fixed it. I bought WD40 at Walmart.
Sounds like the aged PTC thermistor is causing your problem. It is built in the motor in series with the winding to limit the current. The purpose of it is to avoid the overheating of the windings. It increases the resistance when it is warmed up. It has a turning point called "Curie Point" which is explained here.
Hmm, I will have to give it a try. I also will see about cleaning them too.
So messing around the driver side switch does seem to stick more than the other ones. I know someone said to clean them, I was wondering if someone can show me where will I be looking to find the debris?
The motor costs 25,272 Yen in Japan. But searching the parts catalogue today, I found it's not available any more.
I once have fixed the motor only replacing the PTC thermistor with another one at my own risk. But the original one used in the motor was not available and I had to try using another one which I found at Akihabara Japan.
It's been working perfectly fine for years but this may not be the correct way to fix. As I use newer capacitors for the ECU and others, I often use newer and easily available parts replacing failed old ones in the different units although it needs some knowledge and skills to do but so far my trials have been all OK. In order to keep old cars running on the road, my ways of replacing parts are sometimes needed, I believe.
I can't seem to find it either guess I will have to replace the entire unit. Do you by any chance know what the part number is?
Sorry just saw the part number on the images and they don't fit the 2nd gen (I have a 96). Looking around online I found this one https://www.lexuspartsnow.com/parts/lexus-motor-assy-power-window-regulator-front-lh~85720-50040.html?Make=Lexus&Model=LS400&Year=1996&Submodel=&Filter=()&Location=pd:.
Just wanted to make sure if that was the correct part for my 96?
Sorry just saw the part number on the images and they don't fit the 2nd gen (I have a 96). Looking around online I found this one https://www.lexuspartsnow.com/parts/...)&Location=pd:.
I searched the motor for a JDM 95-97. Try partsfan.com for the investigation for a USDM. The site needs a registration though.
https://www.lexuspartsnow.com/parts/...lenoid,,85720A
I found a dealer that is selling it
https://parts.longolexus.com/oem-par...QtZG9vcg%3D%3D
Also, I know my steering wheel behaves similarly. It will move then stop and I will have to wait a few minutes before it would want to move again. Will the motor on this need to be replaced too and if so do you know what the part is called or what the part number for it?
2004 ls430
Hello,
Thanks
Thanks
On the passenger window that starts to go up but stops then drops slightly, that can be frustrating. Anyone with a 3rd generation LS having the same issues and can provide some insight on what the issue is and how to fix it? Thank you.
I bought a remanufactured cardone pw unit from rock auto and it works great. I had to send in an old window motor i bought off ebay to receive a refurbished one. They may have changed it as now it looks like you can buy a refurbished motor first, and send in your old motor after, for same the price I paid.
