94 LS400 acceleration problems
Old Feb 23, 2018 | 03:23 PM
Shovel's Avatar
Shovel
Default 94 LS400 acceleration problems
My 94 ls400 ran out of gas sitting in the driveway. Got gas back in it and it ran fine for 2 days. Then it will crank but will not accelerate. It just bogs down when you give it gas. It also is idling at 1800 Rpm. It got to where it would turn over but not crank. I had power to the fuel pump but it was not running.
I replaced the fuel pump and the fuel filter and it will crank now but after it sits for about an hour it's like it's lost fuel pressure and it has to pump the system back up before it will Restart
Old Feb 23, 2018 | 08:00 PM
Moarpower's Avatar
Moarpower
There is a chance that the low fuel let sediment ino the injectors. Long shot but possible.
Old Feb 24, 2018 | 07:32 AM
Shovel's Avatar
Shovel
The inside of the tank was spotless and the fuel pump strainer was clean.
Old Feb 24, 2018 | 02:11 PM
cdchase32's Avatar
cdchase32
Default Acceleration problems
Sounds like there is either a leak allowing the pressure to bleed down or your fuel pressure regulator went out. Try disconnecting the vacuum line at the fuel pressure regulator and see if it changes the way it runs.
mfigley
GS - 1st Gen (1993-1997)
Apr 17, 2020 12:34 AM
qewani1
Feb 23, 2015 01:53 PM
cura
IS - 1st Gen (2001-2005)
Jan 9, 2014 09:04 AM
ala1413
Jan 2, 2012 08:03 PM
