Ls 400 issues and solutions
Attachment 474686Can anyone tell me what is this red light for?
Press the mode or function button / located on the steering wheel right side. /
and the message will come up.
Like some "error message" or "brake pad wear"
adeelkhan (02-20-18)
But if the light remain that could prove that the sensor got wrong.
When I bought my car I had to replace it...
Man alive,if you have to have a light come on ,thats the kind of message you want to see!
adeelkhan (04-04-18)
If you've refilled & the light remains on then most likely it's the floater. The floater has a sensor & a piece of foam. As the foam gets old, it absorbed water & sank to the bottom of the tank which then triggered a false error that you're low o fluid. You can either replace it w/ a new one for $20, $30 (kind of expensive for a piece of foam & very little functionality) or disconnect the sensor so it won't sent the telemetry signal to the computer. To do so, you'll have to remove the wheel liner then you'll see a connector at the bottom of the tank/reservoir. Just disconnect it then the light will go away.
melymel96
01-13-17 07:22 AM
vikas
Performance & Maintenance
06-01-11 04:18 PM
