Help with Power Steering!
Old Oct 18, 2017 | 11:01 PM
MrLowpez's Avatar
MrLowpez
Default Help with Power Steering!
Hello All. Looking for some help on the infamous Power Steering on these LS4's. I've searched thru a ton of threads and forums but none with this particular issue have come up. Bare with me here as this is a lot to go thru but any advice or tips will be appreciated.
Rack and pinion was leaking heavily from the boots. I had some time and figured I'd overhaul the whole thing. Power steering pump,hoses,and finally the Rack Assembly. Ordered a MAVAL Reman which remans for Toyota. Installed and...Leak. From the boots nonetheless. Swapped for a second rack. Leaked again? At this point. I'm questioning the EVO component and wondering if the pressure just maxes out all at once and blows a seal? I've been transferring it from the old rack to the last two REMAN ones but in my head the new racks should be sealed regardless of the pressure. Am I missing something? The pump is new with the vacuum solenoid blocked off. Everything's plugged in. Is it just my luck that I had 2 bad racks already? Any insight or advice would be helpful. Can I just pull the fuse to the PS-ECU? Thanks guys.
Old Oct 19, 2017 | 11:38 AM
timmy0tool's Avatar
timmy0tool
sorry to hear of the frustration, what kind of ATF fluid are you running in the system? who makes the pump you are using?
Old Oct 19, 2017 | 08:37 PM
MrLowpez's Avatar
MrLowpez
Toyota ATF. Literally happens within seconds of testing new part.
Old Oct 21, 2017 | 07:07 AM
fixmiester's Avatar
fixmiester
Default Wrong fluid
Toyota specifies Dexron III/IV for the PS, not Toyota T-IV. May not be the total cause, but they are very specific about this.
Old Oct 24, 2017 | 10:19 AM
RA40's Avatar
RA40
Super Moderator
+1 with fixmiester. This isn't the first instance where improperly spec'd o-rings/seals have been used in remanufactured parts. To have two failures at the same place the suspicion is the fluid is not the proper viscosity for the steering system. This may be creating higher pressure than spec'd for. Drain out the Type IV for the Dexron spec'd fluid and see how it does.
Old Oct 24, 2017 | 05:33 PM
UNCNOR's Avatar
UNCNOR
Have tried to buy the Dexron 3 or 4 power steering fluid several times but the local Auto Zone,Advance, and O'rileys do not carry the product.Where are you guys buying?
Old Oct 24, 2017 | 06:15 PM
Moarpower's Avatar
Moarpower
it's also labelled as dx.strange that auto zone don't have it.
Old Oct 25, 2017 | 11:45 AM
RA40's Avatar
RA40
Super Moderator
Weird they don't have the ATF fluids. Walmart should have the proper spec Dexron available too. I've been using Mobil 1 ATF.
Old Oct 25, 2017 | 12:09 PM
bradland's Avatar
bradland
+1 on Mobil 1 Synthetic ATF
RealSC400
Southeast
Jul 15, 2013 12:55 PM
woodt3
Jan 27, 2012 04:41 PM
jessev1
Sep 14, 2011 08:35 PM
AzSc4
Dec 22, 2006 09:48 AM
