2000 ls400 stabiltrak light limp mode
I have been trying to find my problem on here for several days now, without anyone having the same problem I have. I just replaced all the front suspension parts control arm, tie rods and complete brake job. I had to remove the ABS sensor from the wheel hub in order to work on the repairs. I did not disconnect the battery not thinking that it will affect anything. Replaced everything put the ABS sensors back in the hub took the car for a test drive, and the car hesitated with the Stabitrac light flashing on and off. Now it does it on occasion which it is very dangerous if making a left hand turn. Now when I push the ETC button the problem goes away. My scanner does not read any issues pertaining to my problem. Therefore, I was thinking that my ABS sensors are left open and is the cause to my problem.
Thanks in advance!
