98-00 LS400 Traction control problems
Old Jun 12, 2017 | 10:56 AM
nolaguy's Avatar
nolaguy
Default 98-00 LS400 Traction control problems
Hi all,
I have owned my 99 for almost a year now and have recently done the timing belt, water pump, valve cover gaskets and replaced most of the front end parts and upgraded the wheels to 18" ls430. I just got it out of the shop having the front end aligned. Since the new wheels have been on the car I have been having problems with the traction control light flashing (more times than not it causes it to not want to accelerate) when accelerating from a stop. I didn't notice the problem with the factory 16's, but I have done a lot to the car since I drove with those wheels, so I am not sure... I have searched and have not found much on this issue. any advice as to where to start?? thanks in advance for the support!
Arick
Old Jun 12, 2017 | 01:35 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
what size are the tires front and rear?
My guess would be drastically mis-sized tires (should be same overall diameter all around) or damaged ABS sensors.
Old Jun 12, 2017 | 01:40 PM
nolaguy's Avatar
nolaguy
Hey Puredrifter-
Thanks for the reply..
I'm running (matching set)245-45-18's all around. I thought about the abs sensors, is there a way to check them? Also- will a faulty front abs sensor cause this sort of problem or would it only be caused by one on the rear of the car??
Thanks!
slammed400
Dec 3, 2016 11:17 AM
Gtzfabb
Apr 25, 2016 11:52 AM
dazpdx
Feb 13, 2008 05:54 PM
dunn378
Jan 22, 2006 11:10 AM
ychachad
Feb 15, 2005 02:56 PM
