No start
Old Jun 1, 2017 | 04:08 PM
Titans2jz's Avatar
Titans2jz
Default No start
So finally got most of my vacuum hoses back connected, I know fuel is going through the lines(took it off and saw fuel shooting out) but still no start. It cranks really fast(not sure if that's a Lexus thing or not) but yea it sounds like its spinning faster than it should be. I have about 5 gal in the tank but the gauge will only move a little bit still reads below E. Any suggestions?
Old Jun 1, 2017 | 09:18 PM
Elless400's Avatar
Elless400
Assuming you have fuel to the injectors, how about spark?
Also, why only "most" of the vacuum hoses?
There's too much missing from this picture for people to help very well, I'm afraid.
Old Jun 2, 2017 | 08:39 AM
Titans2jz's Avatar
Titans2jz
When I gotnit there was like no vacuum hoses so as far as i know everything is back on except the hose that goes to the air intake which i have plugged, if the torrential downpour stops at some point I can check spark
Old Jun 2, 2017 | 11:48 AM
dicer's Avatar
dicer
And always give what year it is, if you had posted before we will still not remember it all. And if you posted this same problem before then continue with that post don't keep adding more posts on the same deal, we need to remember stuff that was posted before if that is the case.
You have to tell us if the starter is turning the engine?
Is this the one where the mice chewed holes in the pistons?
Old Jun 3, 2017 | 10:42 AM
Titans2jz's Avatar
Titans2jz
No this is my first thread about it, year is 93. I finally got around to checking spark today, looks like on the passenger side dizzy is doing its job, have to run to daycare and drip off daughter so later I'll pull the dizzy and check if rotor is spinning. Zeroing down on my issie, will update later
mvanloo
Jun 18, 2018 11:21 AM
fastegg
Jul 27, 2015 05:17 AM
BILKO
Jul 20, 2011 11:11 AM
deanshark
Jan 9, 2011 07:21 PM
Ideal1267
Dec 24, 2005 01:24 PM
