What does your thermostat run at?
Old 05-21-17, 06:55 AM
981uz
981uz's Avatar
Default What does your thermostat run at?
Recently took mine in for over heating, the shop told me that the radiator fan was barely spinning anymore, and that they were able to stop it with a 2 fingers. Now the car runs a smudge past the half way mark is this normal Just for a visual I have taken a picture off the internet and this is what mine runs as at almost exactly regardless of how the car is driving.
Old 05-21-17, 09:39 AM
jakob27990
jakob27990's Avatar
Mine runs just below the half way mark. Maybe your gauge cluster isn't working correctly rather than the car overheating. Something to think about.
Good Luck!
Old 05-21-17, 06:25 PM
YODAONE
YODAONE's Avatar
The coolant temperature needle is at a higher point on the scale than before?
When they say the fan was barely spinning, do they say the fan clutch has failed or the thermostat is not working properly, or both?
What about water pump seal integrity?
Did anyone pressure test the system?
Whatever you do, replacing a 20 year old thermostat wouldn't.be wrong.
Use OEM thermostat, gasket and any necessary FIPG...DO NOT use aftermarket anything here.
If your fan clutch is the culprit, , also replace the fan bracket bearing...again use OEM Aisin brand for these areas....if you use other aftermarket brands,, expect the worst.
For warranty purposes, if employing a shop to perform work, direct them in writing as to which components will be used...otherwise they tend to buy Chinese made over Japanese to increase their profits...
Old 06-13-17, 08:14 AM
LS9698
LS9698's Avatar
Default OEM thermostat and gasket p/n
I just replaced these on my 1998 LS400. Bought from Lexus dealer. Posting pictures.
The old thermostat was 19 yo. Rubber was missing on one side and pulling away on the other. Temp stamped on it is 82 C.
Attached Thumbnails What does your thermostat run at?-2017-06-13-10.04.29.jpg   What does your thermostat run at?-20170613_100239-1.jpg   What does your thermostat run at?-2017-06-13-10.03.48.jpg
JLeffler
04-18-13 08:00 AM
anarchyx
08-03-12 11:52 AM
sfgiants84
IS - 1st Gen (2001-2005)
12-12-11 11:41 AM
cnstarz
07-19-11 06:38 AM
swollio
10-30-07 07:59 AM
Quick Reply: What does your thermostat run at?
