Upstream O2 sensor connection 90 LS400
Old Feb 16, 2017 | 04:01 PM
JoeSuff's Avatar
JoeSuff
Default Upstream O2 sensor connection 90 LS400
I purchased a set of NTK upstream o2 sensors to address an check engine code 25 and trac light. On a 90 LS400 64k miles.
Previously when I bought the car I had a small leak at the rear cat flanges to exhaust pipes. An exhaust only custom shop cut and replaced the bad metal. I reset the lights but they came back.
When I went to install the sensors I was unable to seat the replacement plug into the engine harness. I pulled them and saw the seperator difference. I can't see into the harness on the engine but it's the only thing that seems to make it so I can't seat the electrical part.
I called rock and they said ALL including Denso have the same (+) lifestyle connector and not the (-) like I pulled. I'll buy OEM if I have too But at 3x's the cost I don't wanna spend the money to have to splice harnesses.
anyone else ever have issue?
nms169
Apr 6, 2023 05:05 AM
Nahash786
Jan 3, 2019 07:44 AM
ismike420
GX - 1st Gen (2003-2009)
Jul 18, 2014 06:48 AM
SpencerT
May 4, 2012 03:23 PM
Ab0uMarwan
Jul 19, 2010 06:04 AM
