Check vsc crazy problem
Old Oct 24, 2019 | 12:31 PM
Sin1UZFE's Avatar
Sin1UZFE
Originally Posted by Legender
You need to check your alternator. The first thing to start coming on when you've got low power, not enough juice provided by your alternator is the VSC light.
With the car running make sure you're battery is showing close to 14 volts... I suspect you've got a bad alternator.
If the Power Steering pump is leaking it will most definitely kill the alternator. This is a known problem on these cars.
Based on your description I'd say it's the alternator... at least, that's where I would start.
Mine had a new battery and alternator was going at 14.1v
Sin1UZFE
29
Feb 17, 2019 04:30 PM
Kb422
Sep 11, 2017 06:11 PM
dmrinehart
May 31, 2014 07:33 AM
GS300Dude
Aug 17, 2009 11:10 PM
DaveGS4
Feb 6, 2005 11:32 PM
