Bypass Factory Nakamichi Sub for this...
Old 08-16-16, 08:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
If the sub isn't setup for free air it can easily over-extend and damage the cone/surround. Make sure whatever you buy is meant for free air applications.
Also, the P2 you linked was rated for 250w rms, the amp you linked is rated for 500w rms.....
Old 08-16-16, 08:55 PM
python
python's Avatar
Originally Posted by djamps
How do you like the bass? Mine is plenty loud it just has such a narrow pass band between the trunk and front of the cabin... rap music slams but anything else doesn't have as much bass punch.
it sounds really good..very crisp and clear with just enough bass. as a rule sealed enclosures take more power to put out bass but if u can drive a sealed sub(a good one) u will get better results.
Old 08-16-16, 08:57 PM
python
python's Avatar
Originally Posted by hotdawwg
Now I am thinking I should do something like this:
Drop this Sub into the factory sub location:
http://www.sonicelectronix.com/item_...ch-P2D2-8.html
Then power it by this:
http://www.sonicelectronix.com/item_...e-R500X1D.html
Is this something that would realistically work or is this overkill on the rear deck.
My music taste is very Electic... From EDM to Rap to Country. I am allover the place!
i have this exact sub..i used it a quickly got something that would add better bass. its still sitting in my rear deck unused.
Old 08-16-16, 10:09 PM
hotdawwg
hotdawwg's Avatar
thank you PD. Your input is always valued.... I will do a little more research and circle back with an update. Heck, I may end up just replacing the entire sound system at this rate. Might as well get a nice 5-channel amp and keep the amp under the passenger seat lol...
Old 08-17-16, 10:47 AM
djamps
djamps's Avatar
If you want to put an amp under the pass seat it's got to be small. The mono rockford amp you originally posted does fit, barely, after trimming the plastic heater vent (I used to have that same amp). For a 5 channel with decent power output that also fits it gets costly, something like this (which is a great amp BTW):
http://www.sonicelectronix.com/item_...ne-PDX-V9.html
Old 08-18-16, 06:29 AM
python
python's Avatar
alpine makes great stuff and sonic is where i always shop..good advice, djamps
PandaGS300
09-14-15 08:34 PM
sqa4life
07-23-11 11:02 AM
peter007
ES - 5th Gen (2007-2012)
08-10-07 12:43 PM
dung0981
01-29-07 09:36 PM
Quick Reply: Bypass Factory Nakamichi Sub for this...
