Delayed Engagement
Old Aug 10, 2016 | 05:12 AM
  #31
sam12345's Avatar
sam12345
Worn solenoids, most likely the 1 to 2 solenoid easy to change
https://www.clublexus.com/forums/ls-...-solenoid.html
Old Aug 10, 2016 | 08:20 AM
  #32
Najeeh's Avatar
Najeeh
If the shift solenoids are worn out then its better for me to change the transmission out completely as a whole transmission is available for $180-250, while the cost of a solenoid kit or just even 2 solenoids exceeds it. Also to just clear things up some more, I have no O/D codes, the ecu caps have been replaced, the wiring harness in the trunk is fine. Only problem is with the No.1 vehicle speed sensor, the one currently installed is not from this transmission and does not give the correct pulses, thus the speedometer shows incorrect speed.
Old Aug 13, 2016 | 06:03 PM
  #33
sam12345's Avatar
sam12345
I had no codes either. This replacement transmission, how many miles? Solenoids start crapping out at 200k on first gen. Gs400 has 237k and tranny is still silky smooth
Old Aug 14, 2016 | 02:45 AM
  #34
Najeeh's Avatar
Najeeh
Well mine just reached a 100k miles,165000 km to be exact. That is the kind of mileage where solenoids should not go out. If I'm going to get a replacement trans, I may get the complete engine as well to swap into my cressida. We have to find engines here if we want a low miles one, but generally the average engine here has 60-100k miles on it.
Old Aug 14, 2016 | 04:37 AM
  #35
sam12345's Avatar
sam12345
At 100k it may be something else.
Old Aug 14, 2016 | 04:43 AM
  #36
AaronUCF11's Avatar
AaronUCF11
Thats why shops have said just replace the trans.
Ive found my speedo is out aswell. Unsure why as tyre size is close to original.
Old Aug 14, 2016 | 05:19 AM
  #37
sam12345's Avatar
sam12345
I put an aftermarket solenoid for like 40 bucks or so. Not recommended but so far so good. And I dI'd it myself, drop pan replace, put pan back on. You can get used solenoids on ebay also. But to each his own
Old Aug 14, 2016 | 05:49 AM
  #38
Najeeh's Avatar
Najeeh
I know that there are solenoids that are cheap and easy to replace but getting things here from ebay or any other site is a pain in the neck. The shipping is too expensive and we a 60% custom duty on the overall cost of the import on all car parts regardless of new or used.
Another thing that I've started to notice is that there is a delay in shifting from 1st to 2nd, it changes gear, lags for half a second and then accelerates accordingly.
Old Aug 14, 2016 | 02:08 PM
  #39
AaronUCF11's Avatar
AaronUCF11
What is the trans fluid condition?
Old Aug 14, 2016 | 03:48 PM
  #40
dicer's Avatar
dicer
What if the parts where free then is there still a customs cost percent?
Old Aug 14, 2016 | 08:53 PM
  #41
YODAONE's Avatar
YODAONE
How about if the person sending you the parts inserts a note saying they "are actually returning the parts to you for a full refund" ?
Old Aug 14, 2016 | 09:59 PM
  #42
lextout's Avatar
lextout
could be tranny mounts, brake pads weak or maybe not pressing the brake pedal hard enough.
Old Aug 15, 2016 | 12:52 AM
  #43
AaronUCF11's Avatar
AaronUCF11
Did you watch the video?? Its chirping the tyres. Thats not a broken mount.
Old Aug 15, 2016 | 05:59 AM
  #44
Najeeh's Avatar
Najeeh
The brakes are fine, the brake pedal was depressed at least 50%. The mount is in good nick. Gear oil has been flushed 200 km ago. Will do another once 500 km is reached.
If the parts are free, they ask what was the shipping. If we tell them if the shipping is free, then they flag it as suspicious and take a long time in clearing it. The only way to avoid customs is if somebody coming here has brought these with them as personal baggage.
stratman
IS F (2008-2014)
23
Jul 5, 2012 09:45 PM
x10civ
RX - 3rd Gen (2010-2015)
Mar 6, 2012 06:47 PM
Daber
HS 250h Model (2010-2012)
20
Mar 19, 2010 09:04 AM
hung8852
Dec 11, 2006 03:30 PM
ILOVEGIRLS
Performance
Jul 13, 2004 06:43 PM
