how to fit 17" GS400 rims on 97 LS400?
Old 06-16-15, 08:16 PM
sxe10ucf20
sxe10ucf20's Avatar
Default how to fit 17" GS400 rims on 97 LS400?
Hello eveybody im new to the forum and I recently picked up a cheap pair of GS400 17x8 wheels off a 98, and im pretty sure they will fit on my 97 LS400 with the same bolt pattern but I heard that the front brakes might rub on the rim, I allready purchased the wheels and want to try and make them fit so my question would be will spacers prevent from rubbing and if so what size spacer and brand is safe and reliable? Thanks
Old 06-16-15, 08:39 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
15mm front is a safe size and 12mm may also work. To balance the rears 20-25mm. H&R isa favorite along with Project KICS. I have the Ichiba on the rears of ours and they are popular as well.
Old 06-16-15, 08:49 PM
sxe10ucf20
sxe10ucf20's Avatar
Thank you, ive been meaning to join for a long time, I will look into those...
Old 06-16-15, 09:06 PM
sxe10ucf20
sxe10ucf20's Avatar
I looked into all 3, all are around the same price what brand had the best record? Was it h&r?
Old 06-17-15, 06:25 PM
timmy0tool
timmy0tool's Avatar
confirm first if the wheels will rub on the calipers. i'm thinking GS400 wheels should have ample clearance but i may be wrong. confirm first that you need spacers before buying them.
i personally like H&R best but it depends on the size of spacer, 10mm 15mm etc. anything bigger than 5mm, extended studs should be used which is included in the H&R kit. installing the studs is the second hurdle.
Old 06-18-15, 06:40 PM
sxe10ucf20
sxe10ucf20's Avatar
Yeah I was thinking about just trying to fit before I buy, I just did research and I found that the ucf20 will need spacers for other lexus wheels because of its big calipers. Whats the hurdle with installing the studs?
Old 06-18-15, 06:48 PM
sxe10ucf20
sxe10ucf20's Avatar
Old 06-06-16, 12:35 AM
JALS400
JALS400's Avatar
Default Update?
I know this thread is about a year old, but I was wondering if you were able to clear the calipers with gs400 wheels? Pics?
Old 06-06-16, 03:59 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
2GS wheels won't clear the brakes.
panda86
IS - 1st Gen (2001-2005)
06-07-22 11:44 PM
CarreraS
02-24-16 05:18 PM
noyz25
Suspension and Brakes
03-02-11 02:18 AM
LIVN XL
Wheels, Tires & Brakes Forum
10-21-06 03:19 PM
seanl
05-11-02 04:59 PM
Quick Reply: how to fit 17" GS400 rims on 97 LS400?
