specs on tps (96 ls400)
was checking some vacuum related stuff with the torque app and noticed that when I go WOT the throttle reads at 66.3%. long story short I ended up testing the TPS. 5v input, .5v at idle and 3.6v at WOT. at first I thought this meant it was bad (most online guides I found for testing said it should be 90-95% of the input voltage at WOT) but I've asked a mechanic and he said they dont usually go bad on these cars and I should check the values they're supposed to be.
problem is I can't find any of the values they're supposed to be lol.
so I need either one of two favours:
A. if anyone knows what values I'm supposed to get would you be kind enough to shed some light?
B. if anyone has a 96 or similar ls400 and the torque app or a scanner what values does it give you at idle at and at WOT? for me it shows 9% idle and 66.3% WOT
