No, starter! 98 ls400
Just got my car back, it was $800. He said it was a heck of a job and that if an LS ever came back in the shop for this job he would pad it more! He showed me the old starter and all the gaskets that he took off. He also said there was a lot of acorns and leaves on top of the block, almost like a nest and thought something may have chewed wire at first but that wasn't the case.
As far as my two codes that I was throwing, he said the all the sensors are working how they should but both sides had exhaust leaks. They leaks are located in front of the cats by the hangers by some vibration damping pieces. He recommended cutting off the hangers, removing the dampers, welding over the pipe, reinstalling the dampers and welding back on the hangers. Estimated about $100 to do it. Is this something I can do? I even remember reading about a member who took some thick foil of some sort and used hose clamps to seal it up and it worked and is still working. Or what about exhaust tape? They still make that stuff? I just really can't handle another repair bill right now.
It could be your starter relay but not likely. Still it would not be a bad idea to check the relay. Failing to crank is not the ECU if you are hearing the click of the starter solenoid contacts coming together. That is where you need to determine that the solenoid is being powered. Easy to do.
Locate the starter relay and pull it out..it just plugs into a socket. It is under the Relay Box Cover in the engine compartment and marked "ST". Then check it for continuity across the contacts. Energize the coil with +12v and make sure it pulls in the contacts. Following is a check list. You need to be a able to use an ohmmeter and carefully apply 12v (step 3 energizing the coil should be limited in time...maybe just a few seconds at a time to keep from portentially overheating the coil).
1. Using an ohmmeter, check that there is continuity between pins 1 and 2.
If there is no continuity, replace the relay.
2. Check that there is no continuity between pins 3 and 5.
If there is continuity, replace the relay.
3. Apply battery voltage across pins 1 and 2. You should hear the relay click in. If it does not energize, replace the relay.
4. Using an ohmmeter, check that there is continuity beween pins 2 and 5(should be < 1 ohm). If no continuity, replace the relay.
PickupStix
06-19-16 11:12 AM
