Front movement left to right when braking
I have this problem of whole front moving to right when braking. I am sure this is something everyone would be experiencing on LS. Anyone know of reason any possible solution of the problem? If this problem has been posted somewhere, a direction to search would also be helpful.
When a brake is applied, it seems the whole front is quickly move to left little bit then to right. Thanks in advance for your reply.
Jack the front of the car up and try to move the wheel from side to side and up and down if that makes sense. movement from side to side would likely indicate a bad tie rod and up and down would probably be a ball joint. IDK what wheel setup you have but when I put 2.5 gen wheels on my 1 gen it seemed 100x better with 225s on it then with the narrow 205s from the factory.
Other than those above advices, I suggest you to check ball joints under the struts.
Lower Ball Joint
I will definitely check for lower ball joint for movement in detail. I've moved them with my arm when the car up and did not feel the any looseness...
What bushings are part of the steering rack bushings, other than lower arm bushing?
I've recently have done a four wheel alignment and they usually check for any affecting components for looseness. They did not say anything.
the steering rack has two sandwich bushings that hold it to the subframe. check those bushings for cracks or stress marks. you can have a helper steer the wheel from lock to lock while you look under to see if the rack deflects. some deflection is normal but over 1" of play is bad.
Solved – Front Sway when Braking
The problem is solved. Actually the problem is NOT on the front end, it was the rear. It may sound funny but I was in the process of replacing rear Carrier Arm Bushing. I replaced the left side first then I noticed the front sway problem. I just could not relate what I’ve done in rear with the front sway problem.
Last night the rear right bushing is changed and today I’ve noticed the front sway problem is no longer there. Then I realized the function of the rear Strut Rod. Its function is to keep the rear arm in place from moving forward or backward (along with up and down). If you have a worn Carrier Arm bushing, you will experience the heavy vibration when braking. Although the rubber part of my bushing was completely gone on both side, I did not experience the heavy vibration when braking. I had a "clunk" noise going over a bump at 5 MPH speed. The clunk is gone for good with a replacement of rear carrier arm bushings.
When left rear side is corrected, the right rear had more room for a forward/backward movement when braking casing what appeared to be front sway problem. Replacing the right rear bushing corrected the problem. Just wanted to share my experience.
Thank you all for trying to help, especially timmy0tool.
BahHumBug
http://www.lexus.com/contact/pdf/1990/1990LSspecs.pdf
