Coolant leak - cancer can not be cured?
Old 12-11-14, 11:52 PM
  #31
qha_vn
qha_vn's Avatar
got the root cause, it was a blown head gasket. The other day on my way to work in the morning. the car suddenly lost its power. it ran as if it had only 2 cylinders operational.
pressure tests showed 2 cylinders lost compression (only 7kpa or below, while others got 11 to 13). I decided to get the cam blocks removed. Head gasket was blown, coolant came into cylinders and got burned there. that was why I was losing coolant.
I bought a head gasket set and got it replaced. no coolant loss now. solved it.
Thanks guys for your recommendations and advises. I am happy now. Cheers
Old 12-12-14, 04:05 PM
  #32
timmy0tool
timmy0tool's Avatar
what the motor taken apart before the head gasket problem? very rare to hear a blown head gasket from a factory assembled motor, but glad you found the problem and resolved it quickly!
ls400nyc
13
04-17-18 10:23 AM
thaeleelyr
04-09-16 10:53 AM
aespinalIS
Build Threads
03-13-15 12:37 PM
bryanc182
10-14-11 02:38 PM
jimmac79
Performance & Maintenance
06-22-07 11:58 PM
Quick Reply: Coolant leak - cancer can not be cured?
