Can't remove glove box to access CD Changer
I have removed the following screws
What steps am I missing to remove the panel to remove the CD Changer? Thank you - mcrypt |
https://www.clublexus.com/forums/sea...archid=3899440
There are 5 to 6 different threads on the first page alone that should be able to aid you. This one seems to solve most peoples problem: https://www.clublexus.com/forums/288233-post2.html Good luck with your "search". |
the secret is to keep on reading until you understand what you are reading, and get a minds eye view of what you have to do,,,, you cant just read it one time and go and do it or you could do it without reading it... think of schooling, it was not so much what you learned, but you learned HOW TO LEARN... that principle still works today.. you can do it....
Well the issue Is that when I pull from the right side of the lower glove box I feel resistance when pulling the glove box out.
I don't want to snap the lower glove box to get to the 2 bolts in between the lower and upper glove box, are there hidden clips that I need to pull down on before pulling the lower glove box out? |
1 Attachment(s)
I personally just go really slow on trim work, because it is easy to rush it and get these kinds of problems, - but that is the only way I can make it look like new is to go slow and study the logic behind the factory thinking!
this should help: https://www.clublexus.com/forums/ls4...ent-issue.html and https://www.clublexus.com/forums/ls4...glove-box.html READ AND UNDERSTAND: |
also see this: http://www.youtube.com/watch?v=-EuZW...ature=youtu.be
Originally Posted by billydpowe
(Post 8627608)
Is it normally fairly easy to pull it out? |
Try this link if it doesn't work. Go to youtube and search ls400 cd changer removal. |
My bad I didn't notice that Billy had already given it to you.
Originally Posted by mcrypt
(Post 8628750)
I'm at the part where he pulls out the lower glove box from the right side, but when I start to pull mine i'm putting in way more than a reasonable about of force and decide to stop before I break the plastic.
Is it normally fairly easy to pull it out? can anybody out there help answer his questions?? |
There is a triangular trim piece on the lower right. It has to be slipped out and there is a bolt under it which must be taken out. Be careful, as you can see, I broke mine.
https://cimg8.ibsrv.net/gimg/www.clu...b2275b58bd.jpg |
| All times are GMT -7. The time now is 10:04 PM. |
