How to remove glove box
Old Oct 4, 2013 | 05:46 PM
whokidd's Avatar
whokidd
Default How to remove glove box
I want to replace my control blower motor on my 1996 LS400, but I have no idea how to remove the glove box. Can someone tell me how I would remove the glovebox to install the control blower motor. Thanks
Old Oct 4, 2013 | 06:21 PM
LScowboyLS's Avatar
LScowboyLS
this diagram will help somewhat - keep in mind there is a hidden fastener, behind a secret panel, inside the glove compartment!
Attachment 498614
Old Oct 4, 2013 | 07:19 PM
whokidd's Avatar
whokidd
[QUOTE=LScowboyLS;8172684]this diagram will help somewhat - keep in mind there is a hidden fastener, behind a secret panel, inside the glove compartment!
Where is this hidden fastener? I took out all the screws and can't seem to get the glove box out
Old Oct 4, 2013 | 07:49 PM
LScowboyLS's Avatar
LScowboyLS
the hidden fastener is behind a secret panel, inside the glove compartment!
do not force anything, keep searching for fasteners you have missed - they are there!
Old Oct 4, 2013 | 08:16 PM
RA40's Avatar
RA40
Super Moderator
I'll snap a pic tomorrow. If you start on it before a pic is up, the left side of the glove box has a squarish opening to insert the appropriate tool to undo the fastener.
Read this thread as well. Breaking tabs is
https://www.clublexus.com/forums/ls4...ent-issue.html
Old Oct 5, 2013 | 12:04 PM
billydpowe's Avatar
billydpowe
this might help you.....
File Type: doc
Old Oct 5, 2013 | 04:35 PM
j5ive's Avatar
j5ive
10th Gear
I found this when I had to replace my CD changer on my 96. The process is very similar if not the same.
Good luck.
Old Oct 5, 2013 | 07:21 PM
RA40's Avatar
RA40
Super Moderator
That video covers it and the glove box is pretty straightforward. When the glove box is tilted down, there are three screws that also fasten it in. They are all in a straight horizontal line across. The left most is this one so follow it across to the two other Phillips heads:
leonrojo18
Jul 19, 2021 06:06 AM
audreyduey
Dec 12, 2013 06:11 PM
12340987
Jun 26, 2010 10:05 AM
Spotnsabby
Nov 22, 2006 02:12 PM
lovemov
Jul 30, 2004 10:17 PM
