HELP: CD Changer
Old Jan 31, 2003 | 10:01 AM
SappyEF9's Avatar
SappyEF9
Default HELP: CD Changer
Does anyone know how to get to the in dash CD changer in the LS400? The changer is stuck on a CD right now! Help!!
Kenny
Old Jan 31, 2003 | 05:58 PM
lexusaudio's Avatar
lexusaudio
Default ls 400 glove box cd changer removal.
you have to remove all the screws around the upper cd changer compartment. the lower glove box is attached by 2 pop out spring which are attached the the metal support between upper and lower glove box. once the lower box is pulled back the screws holding the cd changer are visible. after removing the cd changer unscrew all the small 4mm black screws holding the case in place. the bottom of the changer has a magazine release so the magazine can be ejected and can be removed.. however if the cd tray is stuck you will need professional help to remove without damaging the changer,. hopefully you will be able to remove the magazine and leave the stuck cd in its tray. then remove all other trays and reinsert the empty magazine devoid of the other 5 trays.. hopefully it will eject it into the empty magazine since there are no other magazines to interfere.
i could email pictures if you send your email address by pm(personal message)
Behemoth7
Aug 18, 2022 11:34 PM
tsxnbp
14
Mar 9, 2014 09:23 PM
Rommel
Feb 16, 2012 06:39 PM
T.K.O.
Dec 1, 2009 01:03 PM
