ls400 steering problem
Old Aug 21, 2012 | 06:49 PM
ROADKILL's Avatar
ROADKILL
Default ls400 steering problem
Hi All,
seems that i have something a miss with my steering! Basically if i go around a right hand corner (ie full turn of the wheel) when i straighten up on the road, the wheel is still pointing maybe 10 degrees to the right. If i then go around a left hand corner (full wheel turn) and then go back to driving straight, then wheel is then pointing about 10 degrees to the left. Obviously something is loose either in the steering rack or there are some shagged bushes. I don't however hear any clunking or banging noises though i am yet to double check these on full lock.
Any ideas where i should start or potentially how to tighten up the rack if it has maybe worked its way loose?
Thanks in advance,
bEn
Old Aug 22, 2012 | 06:37 AM
billydpowe's Avatar
billydpowe
yes, you should start under the car, and see what is moving around under there while someone turns it from side to side....... then get out, if necessary, and tell us what you found/discovered and see if any of us have had that problem and how we corrected it. the forum is not trying to guess all the different things that Could go wrong, but about trying to help each other...... so, go for it.
Old Aug 12, 2021 | 08:49 PM
serg25's Avatar
serg25
Hey did you ever find a solution? just had this happen to me yesterday
Old Aug 13, 2021 | 01:16 AM
400fanboy's Avatar
400fanboy
Like the gentlemen from Texas said, there are a million different things it could be. It's guesswork. You have to get under the car and inspect\confirm for play in the steering rack. Could be bushes could be tie rods could be the rack & pinion itself could be the u-joint in the column who knows.
Old Aug 13, 2021 | 11:44 AM
RA40's Avatar
RA40
Super Moderator
Plenty of areas to check. For one the steering rack bushings.
UR2klose
Dec 14, 2018 10:45 AM
JJ823
Feb 9, 2012 11:53 AM
father
Sep 24, 2010 09:43 PM
reddlexus
Mar 24, 2007 07:30 AM
Din
Maintenance
13
Oct 26, 2005 02:02 PM
